Shelby Group, Any ideas, on a good system for restoring original 67- 68 Shelby Ten Spokes ? 1 We are starting, by glass beading, the intire surface 2 We have plans to paint the rough surface, with semi-flat clear 3 Next step, the wheels will be measured by a C & C machine, then having one mill removed, to duplicate the original finish. Should weclear coat over the milled areas also ? Anyone had experience with restoring these ? Can you advise a better system ? Pete Geisler Orlando Mustang 407 688 1966
Cobra Automotive did mine. They are perfect. Rick & Susan Thompson ----- Original Message ----- From: ORLMUST@aol.com To: ShelbyMustang@carmemories.com Sent: Tuesday, September 06, 2005 1:59 PM Subject: 10 Spokes Restoration Question Shelby Group, Any ideas, on a good system for restoring original 67- 68 Shelby Ten Spokes ? 1 We are starting, by glass beading, the intire surface 2 We have plans to paint the rough surface, with semi-flat clear 3 Next step, the wheels will be measured by a C & C machine, then having one mill removed, to duplicate the original finish. Should weclear coat over the milled areas also ? Anyone had experience with restoring these ? Can you advise a better system ? Pete Geisler Orlando Mustang 407 688 1966
