Getting ready to drop my 428PI back in, but have had no previous experience doing this on a car with a manual tranny (4sp Toploader). From what I understand, it really just entails slipping the motor onto the tranny shaft. What I'm concerned about is the clutch. From what I've been told, there is an alignment procedure that you have to do with the clutch/flywheel and there is a tool required for this. Is this tool available for purchasing or rental at a place like Advance Auto. Can anyone outline what needs to be happen with this tool as far as a specific order of the process? Just trying to avoid the "get it right or regret it later" mistake due to my in-experience... Thanks, Bob
Its called a pilot tool. Nowadays a lot of clutch suppliers put a throwaway ones in with their clutch kits. There is also a universal one that has a cone on a shaft. Its pretty simple. The tip of the shaft goes into the pilot bushing in the end of the crankshaft (make sure theres one in there) Then the disc goes over a step on the shaft (or centered by the cone) that centers the disc to the pilot bushing. Finally attach the pressure plate with the 6 bolts. Make sure you tighten them evenly and torque them. When inserting trans into bellhousing/clutch make sure it goes in freely. Never force or draw in with bolts.Oh and one more thing, don't forget the spacer plate before you put on the flywheel. Everyones forgotten this at least once in their life. Here's a specific app one, http://www.autozone.com/az/cds/en_us/0900823d/80/04/b8/fd/0900823d8004b8fd/repairInfoPages.htm And a universal kit, http://www.amazon.com/dp/B000HTNNWG...e=380333&creativeASIN=B000HTNNWG&linkCode=asn
Tim, Thanks for chiming in... I purchased a new RAM clutch that I still have in the box but was actually thinking of using the clutch that was in it previously since it only had about 800 miles on it. Do you think that the alignment tool would be in the package? Let me know what you would do if it was your car (as far as going with the old versus new clutch). I've also purchased some of the bushings and a throwout bearing, but have been waiting for them to arrive along with my fuel sending unit..... Been almost 3 weeks since I ordered them from Metro Parts Market... I called them on Tuesday and they said I would have my stuff by today... I sure hope so otherwise I'm not going to be able to do this on Saturday...
Bob, I always screw a couple studs or bolts with the heads cut off about 5" long into the bellhousing. With the transmission on the studs, the trans. is at the correct height as you slide the trans. through the clutch and get the trans. seated on the bellhousing. It makes it a lot easier to control the trans. with the weight of the transmission on the studs. kenny
Hi, Any automotive store has a clutch pilot tool for the smaller splines but I am not sure about the big splines for the 428PI. However, they are made by plastic and cost a few dollars. As regards the clutch, did you have your rotating parts professionally balanced? If you did, and the clutch was part of the balancing you need to use your 800 mile clutch. I had my 289 HP in my 65 Shelby balanced with my clutch and soon thereafter, before putting the engine in the car, I found a NOS complete clutch. Went back to the balancing shop and they balanced the new clutch for my engine and marked it how to put it on. I put the transmission on the engine and put the whole thing into the car but that may be impossible with a big block. Good luck, Texas Swede
I think the RAM clutch comes with the tool. Tough call on old vs new. I really like the RAM clutch in mine.
Thanks guys, really appreciate the feedback... I'm starting to get a little bit of confidence on this... I know it isn't brain surgery, but.... One last question on this... My tranny is still in the car, being supported from underneath and still attached to the tranny crossmember. I've had people tell me that I should pull the tranny and attach it to the motor before dropping in, but others saying it would be fine to leave it how it is and drop the motor in... Can anyone talk from experience as to which way would work best? Thanks again for all the help, I'll try and snap a couple of pics once I get everything dropped back in and post them here if possible... Bob
Personally I like the tranny out when I put engine in. Theres just not a lot of wiggle room. The way I like doing FEs in Mustangs is assemble the engine as completely as possible, exhaust manifolds,plugs, wires, smog, alt, PS, AC, clutch. Everything but fan blade and bellhousing. This way you can drop it in straight down and not scratch up your pretty painted engine compartment and better yet you're not trying to get your hands in places they don't fit like installing plugs etc. Then bolt the bellhousing from underneath with TO bearing installed and then lift trans in place. In my younger days I used to lie on my back with trans on my chest and lift into place but now I need a jack under it.
Attach everything, including bell housing , less the the tranny, and power steering, they can be hooked up after. i think its impossible to put both in at once . well it may be possiblebut the engine will need to be vertical . thats dangerous to me . protect as much as poss, and take your time , and its a piece of cake . let us all no how you made out !! THX, John from over the pond !!
if you do have freshly painted shock towers you may want to use some stratgicly placed card board as paint protectors...
You CAN install the engine/tranny as a single unit. The factory did it that way. In order to do so you must do two things: get the REAR of the car as high as possible (and I mean high - not 6 inches off the ground) and get a load leveler to hang the motor/tranny from. The engine/tranny must be at a very sharp downward angle. Also the steering linkage must be dropped down (by unbolting the idler arm) and the cross member removed. You will also need an engine hoist that can reach really high to clear the radiator support. Since you have a 4-speed I would install the tranny later BUT make sure the bell housing is installed. Before putting the engine into the car test fit the tranny into the bellhousing. It should slide in and out easily and should seat completely against the bell housing without any BFH persuasion. The suggestion of putting studs into the lower bell housing holes is a good one.
Also a quick note........ If using the Pilot tool that comes with the kit, make sure it fits both the Clutch Disc and the Bushing/Bearing that goes in the back of the Crank. I installed a Ram Clutch in my last Car and the Tool fit the clutch fine, but the tip that goes in the Bearing was to skinny.......it needs to be very snug so the Clutch Disc does NOT slip down. If it slips down, even just a tiny bit, the Trans will not slip in.
Guys, Thanks for the help... Got the motor dropped in yesterday. Ran out of light before we could get the toploader back in though. Was hoping to be able to put the tranny in with the shifter stick still on (as there doesn't seem to be an obvious way to remove the stick), but after doing a couple of test runs it looks as though it will have to come out. It is a Hurst Competition plus shifter. Found their FAQ page and it mentions about sticking feeler gauges down on either side of the stick, but this stick seems to have a sort of open box makeup where it attaches to the shifter. Anyone have any ideas on how this removes? Thanks, Bob
When I used to stab transmissions in & out of early Mustangs I had a spare front drive shaft yoke stuck into the back of the trans all the time. First, it kept fluid from dripping out. But more importantly, I could put the trans in gear, then I could reach up and rotate that yoke on the back of the trans to get the input shaft of the transmission to rotate into alignment with the clutch splines during the final few inches of the stabbing procedure. I hope I explained that right. Steve
Guys, Thanks for all the assistance... we were finally able to get the tranny in yesterday. We ended up pulling the shifter completely off. Now just need to get the PS lines run to the cooler, install the pump, radiator and hoses and she should be ready to fire up... Doubt I'll have much time to work on her during this week, so most likely next weekend... Bob
