6200 rpm break-up
Discussion in '2nd Generation Shelby Mustangs' started by Mambo1960, Sep 10, 2007.
  1. Mambo1960
    Mambo1960 Active Member
    Austin, tx
    Hi all- new to the forum, is there something that causes the engine to sputter and puke when the rpm's get over 6K?
    2007 shelby gt
    thanks
  2. DJR
    DJR Well-Known Member
    Ontario,Canada
    Rev. limiter. Ask the dealer what rpm it is set for. Same thing happens with my buddies car.
  3. Mambo1960
    Austin, tx
    Will check- thanks- is there an adjustment possible and if so, what is the recommended max rpm
  4. DJR
    Ontario,Canada
    Most likely not. Keeps you from over reving the engine. Warrenty would be void if changed. Computer controls all that stuff. You could ask the dealer what bolt ons would be allowed under the warrenty. A smaller pulley and better air box is worth around 100 horse I've been told. Can't say it is true or not.
  5. Mambo1960
    Austin, tx
    Thanks, I guess I'm just used to higher revving engines, 6 or 4 cyl. When I first got the car I thought it was really powerful, it is, but I guess I'm getting used to it, and it seems like it could use an extra punch. I'll live with it for a while, try to find a track where I can really see what it can do and go from there. Thanks again for your input.
