Is the 65 289 K Code Carter 3939S fuel pump rebuildable...The stamped together ones with the Button top?? Thanks JW
JW: Several years ago, when my original Carter fuel pump (which is the same type as yours) started to leak on my 67 500, I must've made about 20 calls to different fuel pump rebuilders and everyone told me that it wasn't rebuildable and to "throw it away" (yeah right). I finally found a guy who did it, and it came out great. I believe the name of place is A to Z fuel pumps. I have the box with the company name and address in my garage. I'll have to get it and get back to you. Kenny PS I also heard that recently a guy in New Zealand started doing them as well, but have no info on him. -----Original Message----- From: fordmond (AT) swbell (DOT) net To: shelbymustang (AT) carmemories (DOT) com Sent: Fri, 10 Feb 2006 23:26:32 -0600 Subject: 65 K Carter Pump Is the 65 289 K Code Carter 3939S fuel pump rebuildable...The stamped together ones with the Button top?? Thanks JW
