'66 GT-350 paint questions
Discussion in 'Shelby Mustang List' started by MikeLDrew@aol.com, Dec 17, 2005.
  1. Hi guys,
    I'm in Troy, Michigan, blowing my GT-350 clone apart and preparing to send it
    out to be painted. I have quite a few questions for you originality experts
    out there:
    1) What finish should the hood and trunk hardware have? I'm talking about
    the hood catch, the pin that goes into the catch, hood hinges, etc. in the
    front, and the trunk catch, trunk latch, and trunk spring in the rear. On my car,
    most of those pieces are just painted gloss black, with the paint of course
    chipped away where pieces touch. Should those be zinc-plated, or cad-plated,
    or ???
    2) My pass-through door (between interior and trunk) was evidently
    originally painted body color on the trunk side, but was then painted black. Same for
    the hinges. Should they be body color?
    3) For that matter, what kind of finish did the trunk have? Most '60s cars
    seemed to be painted with that gray paint-splatter stuff--what about GT350s?
    And what kind of trunk carpet/mat did they use? Standard Mustang?
    4) My car was originally Silver Blue (Y) with Blue w/blue interior (22). My
    interior panels have been repainted black, but it's starting to look a little
    shoddy. What color should be used to repaint those panels, and should the
    doors and dash be painted the same color, or a different color? My trim panels
    are sort of a satin/matte black while the doors are a very shiny gloss black,
    and everything is going to be repainted.
    I have one more non-paint question tonight--there is a drain at the bottom of
    the body opening in the rain gutter for the clear '66 windows (air extractors
    on standard Mustangs). My friend's car has a metal pipe about two inches
    long, with a hose running through a hole that evidently dumps water into the
    rocker panel where another opening lets it go to the ground. My car has just a
    simple hole in the bottom of the rain gutter--no pipes, no hoses. Are those
    pipes available, or do I have to jury-rig something?
    I can send photos if people are unclear as to what I'm talking about.
    Thanks in advance for your answers!
    Mike (tomorrow the motor comes out, and soon a built-to-the-hilt 331 stroker
    will replace it, Zoom Zoom!)
  2. STAN SIMM
    STAN SIMM Guest
    Mike-Am giving you info. from memory here. Let others on the List
    add/correct/modify as compelled:
    hood latch on hood and hook on pedestal-Phosphate & oil
    hood pin-Zinc Chromate
    hood hinges-Phosphate & oil
    Trunk catch & latch-Cad. plate
    Trunk hinges & spring-Body color
    Pass-thru door: Same as interior (black) on both sides.
    Door swing-out arm assy-Cad plated
    Trunk finish-same as exterior (do not paint top of gas tank)
    Trunk mat-Plaid rubber mat (not the cheap one w/fuzzy backside)
    Interior panels, doors and dash-Same as interior (black).
    I recommend SEM paint in spray can or bulk w/spray gun. Use on
    interior metal (doors, dash, rear interior panels, etc....Even engine bay.
    Let it cure for a few days b4 assy. EZ touch-up, too.
    Merry Christmas & Regards, Stan
    To: <shelbymustang@carmemories.com>
    Sent: Saturday, December 17, 2005 8:08 PM
    Subject: '66 GT-350 paint questions
    > Hi guys,
    it
    experts
    > out there:
    about
    my car,
    course
    cad-plated,
    > or ???
    black. Same for
    cars
    GT350s?
    My
    little
    panels
    black,
    of
    extractors
    the
    just a
    those
    stroker
