'67 GT-500 HELP on Vacuum connections
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by snakeoilbrian, May 15, 2010.
  1. snakeoilbrian
    Near the Shelby plant in LA
    HELP!! Can anyone help me with the carb, choke, modulator and brake booster connections? Pictures would be great but I'll take any advice. I have put all new tubes on and things do not fit well. Help me get this baby going!! Thanks!!
  2. Bob Gaines
    Picture of choke tube and fresh air filter below. Brake booster vacuum taken from short metal tube screwed into the fitting on the back of the intake just under the back of the rear carb. The modulator valve vac is taken off of a small vacuum nipple protruding from that same fitting . If you can't find one PM me I can set you up with that and the rare fresh air filter too. Bob
  3. FIA-ERA
    FIA-ERA Member
    Hello Bob, Thanks for the help in the past! Not to steel this thread but what size is the brake booster line going from the back of the intake? I currently have a 5/16" line on there, is that too small? I'm having a lot of booster issues on another thread! Thanks for the help, Matt.
  4. roddster
    If you don't use hose rated for vacuum, it has the possiblity to suck closed. Could be part of the booster problem. This hose has thicker walls.
  5. FIA-ERA
    FIA-ERA Member
    Thanks roddster! I will look into that as well. My booster has two ports on the vacuum tree, a small and a large? Would connecting to the larger one hurt? The motor stumbles right now when I really jump on the brakes so I do think the booster is working but not enough! Thanks again, Matt
  6. Bob Gaines
    Sometimes a symptom of engine stumbling or dying is a sign of a faulty brake booster. A ruptured internal diaphragm allows outside air to be sucked into the engine . The amount of the tear or rupture to the rubber diaphragm would determine how bad it is . I have seen some that have such a big tear that you hear a bad hiss when the brakes are applied and others that it even kills the engine when the brakes are applied other ones have been to lesser degrees when the brakes are applied as you discribed in your situation. I think the metal line is 3/8. I will not be able to take any pictures and post them until at least Monday night.Bob
  7. Bob Gaines
    A thought occurred to me that you may not have rebuilt the choke furnace on the exhaust manifold before installing the engine in the car. If it has never been done there is a 99.995% probability that it is clogged up. If clogged and the engine is installed in the car the choke will not function and you will have to adjust it at the carb to fully open all the time. No chance of fixing it on the car IMHO. It wouldn't work but will look the part. Bob
  8. FIA-ERA
    FIA-ERA Member
    Hey Bob sent you an e-mail. Thanks!! Matt
