I have a few questions about an over the counter 67 Shelby steering wheel that I bought for my KR. . I've noticed some Shelby horn buttons only say Shelby Cobra, instead of 350/500. I would like to get the insert that has only Shelby Cobra, is it a factory insert, or is it another emblem used elsewhere that has been used in the center cap? I would also like some pictures of wheel mounted to a tilt wheel column. I was told I could use a 67 tilt collar on my 68 column since the 68 collar is larger in dia. Thanks, Kenny
I can tell you about what the non over-the-counter horn button emblem has. You can probably find the emblem in repop, check with Branda about that. The lense might just pop apart from the base. Then there is a little round hatch to remove. Then there sits the emblem. I don't know if the splines match the 68 steering shaft. And, on a 67, there is no crash crush area in the column. Beware of that.
