68 Shelby console question...
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by SuperCJcat, Apr 1, 2007.
  1. SuperCJcat
    SuperCJcat Well-Known Member
    Connecticut
    is there a difference between a fastback and a conv?....I was told that Branda list the 2 versions, but I couldn't understand why they would be different....THANKS
  2. daltondavid
    I have never noticed a difference..Calling Peter Disher ...come in PETE!!!
  3. Engineer
    Engineer Well-Known Member
    I believe the floor contour is different between a fastback and convertible. The convertible is contoured to make up for some of the structural loss as the top is removed from the unibody.
  4. TLEA
    There is a different one for vert because of the floor. Its mostly the right side panel.
  5. SuperCJcat
    Connecticut
  6. Coralsnake
    The seat risers are different in a convertible and a fastback, so yes there is a difference. There is also a difference between a 4spd and an Automatic console. The hole is bigger on the auto trans consoles. There are also two different colors...saddle and black. So that makes about six different consoles. :thumbup:
  7. drspencer
    drspencer Active Member
    Could an auto trans console be used on a 4-speed car, or would there be gaps, spaces, issues, etc?
    Thanks
  8. Coralsnake
    You can use a 4spd in an automatic console, but it will look funny. The hole for the auto shift lever is much bigger than the 4spd hole
