69 grille question
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by shotgun, May 21, 2008.
  1. shotgun
    shotgun Active Member
    near St Louis, MO
    Can someone please tell me how the "racetrack" goes on the grille, does the welded seam go on top or bottom?
    Thanks
  2. DJR
    DJR Well-Known Member
    Ontario,Canada
    There should be pins on the back and little metal rectangles slip over them. You might be able to use speed nuts. I put the joint on the bottom.
  3. Bob Gaines
    FYI the original race track trim had square shaped studs or pins and the repros are round shaped pins . The fasteners are round flat push on fasteners that have the red metal dye on them. AMK sells them. Bob
  4. shotgun
    near St Louis, MO
    I have the original racetrack(square pins), the retainers that came off are rectangular. I also have a set of AMK round retainers.
    Which should I use?
    Plus, are there any fasteners for the (6) or so threaded studs on the molding where it goes across the top of the grille?
    Mine didn't have any, and none came with the AMK kits, but looks like maybe there should be something.
    Thanks, Mike
  5. 2dragpac500converts
    2dragpac500converts Well-Known Member
    missouri
    On my survivors, they have square studs and square retainers. The look very similar to an auveco retainer that is out there but the ends look a little different. They appear to be phosphate.
