900K 65 GT 350R car
Discussion in 'Shelby Mustang List' started by jonlee@wt.net, Jun 7, 2006.
  1. I didn't know this until now but the car below got sold for $990,000 at the Amelia Island auction.
    Can be seen at Lot 137
    http://www.rmauctions.com/AuctionResults.cfm?SaleCode=AM06#
    CHASSIS NO: SFM5R102
    350hp 289 cu. in. V8 engine, four-speed manual transmission, independent front suspension with coil springs, live axle rear suspension with leaf springs and front disc, rear drum brakes. Wheelbase:
    108"
    It is impossible to define a Shelby GT350R any better than the Shelby American Automobile Club’s 1997 Registry does.
    “The competition model was the car the GT350 started out to be. Unlike any other production car, from which racing versions are made by modifying street versions, the street model GT350 was created
    by detuning the racing model.”
    There were only 36 R-models built, and they are the fire-breathing, Corvette-beating, heart and soul of the Shelby Mustang lineage. All were Wimbledon white with blue stripes [except on three
    occasions this one, fans of The Ohio State University will note, but more on that later] and they all ran like Jack the bear. They were immediately successful in achieving their intended purpose,
    dominating SCCA B/Production racing in their first season and nearly obliterating other marques and models from the annual SCCA runoffs, then known as the American Road Racing Championship, for the
    next three years.
    The GT350 had one purpose in life, to put the Ford Mustang in the winner’s circle in SCCA road racing. The initiative for the GT350 came from Ford Motor Company which wisely recognized that the
    Mustang’s success with consumers could be enhanced with the performance image which came from racing. Shelby was the logical partner but was already busy building Cobras and supporting a busy racing
    effort including the Cobras, Ford GT40 Mk II and the USRRC/USAC King Cobras. So Ford made it easy, as well as lucrative, by doing most of the hard work itself.
    The first hurdle was SCCA’s requirement that 100 cars be built before the beginning of the year in which they would race. Ford agreed to supply Mustangs to Shelby’s specifications and Shelby picked
    through the Ford parts catalog to specify the basic package that would lend itself to road racing with fairly simple upgrades to be made in Shelby American shop, a project headed by Chuck Cantwell.
    The production cars, and all the R-models, were specially built in sequence at Ford’s San Jose, California factory in Wimbledon White with Black interiors and 271 hp K-code engines, aluminum-case
    Borg Warner T-10M four-speed transmissions, 9 in. rear axle with Fairlane station wagon drum brakes, “export” shock tower brace and sintered metallic brake pads and linings. Left in San Jose were
    the hoods, rear seats, radios and exhaust systems. An additional 15 cars were even more special. These arrived at Shelby without side or rear windows, heaters, defrosters, upholstery, headliners,
    insulation or sound deadening. They were the first R-models.
    At Shelby all the GT350s received basically the same suspension modifications. The front suspension upper A-arm chassis pivots were lowered an inch, Koni shocks were installed along with a one in.
    front sway bar and quick ratio steering kits. The K-shaped “export” brace was augmented with another bar joining the tops of the shock towers. The leaf spring suspended rear axles got traction bars
    and Detroit “No-Spin” locking differentials.
    Other changes included fiberglass hoods with cold air intake scoops, wood-rim steering wheels, and a fiberglass shelf where the rear seats had been. Batteries were trunk mounted for better weight
    distribution and a Shelby tach and oil pressure gauge were installed in a dash top mounted pod. Three in. competition-style lap belts were installed in all the GT350s and Shelby, ever conscious of
    ways to conserve money and time, used the inner belt mounting bolts also to secure a driveshaft safety hoop.
    The Shelby Mustang GT 350R
    Having created the framework within which to meet SCCA’s requirements the Shelby American crew turned its attention to building the few, special competition cars that would campaign in the racing
    season that would be in full swing in only a few weeks. Using the production GT350 as a base, Shelby concentrated on those things which any conscientious racer building a production-based GT or
    sports car would do, improving handling, power and reliability and, by design, the GT350R’s handling was not an issue.
    Engines were blueprinted in Shelby’s engine shop while the heads were extensively modified by Valley Porting Service. A Holley four-barrel carburetor on a Cobra high rise aluminum intake manifold
    was installed, with Tri-Y headers built by Cyclone handling the exhaust. Output ranged from 325 to 360 horsepower on the Shelby dyno. Front and rear fenders were flared for wider tires to accept
    American Racing 15x7 inch five spoke wheels. The engines increased output dictated an oil cooler for reliability. It was mounted behind the special high capacity radiators and required more air flow
    which resulted in the R-models’ most distinctive feature, a new front body apron constructed from fiberglass with a deep air intake flanked by brake cooling air scoops.
    Plexiglas side windows with aluminum frames saved 25 pounds over the stock side glass. A special Plexiglas rear window was formed which fitted the rear light opening with a two in. gap at the top to
    exhaust air from the interior and smooth air flow over the rear body – said to increase the R-models’ top speed by five miles an hour. A four-point roll bar was installed and a massive 34 gallon
    baffled fuel tank fabricated from the bottoms of two standard Mustang tanks.
    When complete, the Shelby Mustang GT350R was a turn-key race car that was ready to go straight from the Ford dealer where it was bought directly to an SCCA race weekend and compete at the highest
    level.
    That’s exactly what happened to SFM5R102, the example offered here.
    Bob Johnson’s 1965 SCCA B/Production Championship R-Model
    One of the first group of 15 R-models built by Shelby, 102 was completed in May 1965 and consigned, not sold, to Bob Johnson in Columbus, Ohio. Johnson campaigned 102 with sponsorship from Ricart
    Ford but with direct factory support from Shelby American in SCCA’s Central Division, augmenting the exposure which Shelby was able to create in the Pacific Coast Division with Jerry Titus’s factory-
    entered GT350Rs and the privately-entered GT350R of Mark Donohue in the Northeast Division.
    Johnson had made a name for himself quickly, racing Corvettes to a 1960 B/Production championship. He recognized the Cobra’s potential when it appeared and acquired one of Shelby’s 1963 Sebring
    Cobras, racing it to SCCA A/Production championships in 1963 and 1964 as well as showing his heels to the USRRC field upon occasion. His victory over the factory Cobras at the Watkins Glen USRRC in
    1963 caught Carroll Shelby’s attention, earning Johnson a series of drives in factory Cobras including Daytona (first in GT, second overall) and Sebring (second in GT, seventh overall) in Daytona
    coupes.
    Johnson was a natural choice to put the GT350R in the winner’s circle in SCCA B/Production, based in Columbus, Ohio and with a proven record as both a finisher and a winner. He was provided with one
    of only four GT350Rs believed by SAAC to have been built as factory team cars (the others being 001 and 002, the prototypes raced by Jerry Titus and Chuck Cantwell, and 096.) They were delivered
    with dual S-W electric fuel pumps, competition bucket seats, baffled steel high capacity oil pans built by Avaid and modified steel valve covers with breathers. Presumably, although not documented,
    these special factory-racers also got the best engines from Shelby’s engine shop.
    The potential of SFM5R102 was immediately realized. Delivered on May 11, 1965, Johnson entered it in the SCCA races at Cumberland, Maryland only four days later, on May 15. Although he qualified
    fourth, a protest (by Corvette entrant Don Yenko) put Johnson and the GT350R at the back of the field. Undeterred, Johnson raced his Shelby Mustang through the pack to challenge Frank Dominiani’s
    Corvette for second overall and first in B/Production in the final corner. The two protagonists scorched the finishing straight side-by-side, with Johnson taking the position before both cars spun
    and crashed through the barrier and into the infield in a race that was – even by the exciting standards of mid-sixties SCCA National competition – a barn-burner.
    The 1965 SCCA season was already in full swing and Johnson had to accumulate points quickly to make the desired, and intended, impression in the Central championship so only two weeks later they
    were back in action at Meadowdale in Illinois. A little playful taunting also was involved. Tom Payne also raced a GT350R (SFM5R099) and Johnson, an alumnus of The Ohio State University, painted 102
    in Ohio State’s grey/scarlet colors, challenging Payne to present his Mustang in the blue/maize livery of his alma mater, the University of Michigan. Payne, perhaps wisely as it turned out, demurred
    and Johnson’s 102 appeared at Meadowdale, Mid-Ohio and Lime Rock as a standout among the uniformly Wimbledon White Shelby Mustangs. When the race results and photos reached Carroll Shelby in
    California he quickly remedied such non-conformity, in colorful Carroll Shelby terms that could not be misinterpreted, with instructions to return the car to the factory white with blue stripes.
    Johnson and his GT350R finished first in class, second overall at Meadowdale, first in both class and overall at Mid-Ohio on June 13, first in class and fourth overall at Lime Rock on July 5, second
    in class at Mid-Ohio on July 11 and second overall and in class at Lynndale Farms on August 8, accumulating a total of 51 points in the division and being declared an SCCA B/Production National
    Champion. Even with the late start to their competition season, the record of both car and driver is only three points less than Jerry Titus accumulated with a full season racing the prototype and
    were equivalent to Mark Donohue’s Northeast Division total in Yale Kneeland’s 5R105. GT350Rs swept the SCCA B/Production championships, taking five of the six divisions.
    At the invitational American Road Race of Champions in Daytona on November 28, seven GT350Rs crowded the B/Production field and the racing was furious and
    fender-to-fender as the period photos abundantly document. While the A/Production Cobras sprinted to the front of the combined A-B/Production field the GT350Rs of Titus, Johnson and Walt Hane fought
    it out with Corvette drivers Don Yenko and Bob Fryer and Merle Brennan’s trick Jaguar XKE. Hane spun after a tussle in Daytona’s infield with Johnson who then finished second in class to Titus, both
    on the same lap as the three A/Production Cobras ahead of them.
    SFM5R102’s Subsequent History
    Following the ARRC Johnson returned 5R102 to Shelby American where it was rebuilt and sold to Ron Dykes via Bay Area Auto Sales in Fremont, California. Dykes raced it again to an invitation to the
    second ARRC in Daytona in November 1966 but did not finish. The next owner, Barrey Robles, garnered 5R102’s third consecutive invitation to the ARRC in 1967 but could not find sponsorship to make
    the trip to Daytona and again won the Cal Club SCCA Regional Championship in B/Production in 1969.
    Old race cars frequently suffer ignominious ends but that fate did not befall 5R102 which was retired from active racing in 1971, still essentially complete in all major respects including bodywork,
    hood, chassis, suspension and drivetrain, and stored until it was acquired by Mike Shoen in 1978. A lengthy restoration followed (fully detailed in the SAAC Registry) during which the Shelby
    American ID tag was separated from the car. Fortunately tempers cooled with the passage of time and tag and chassis were eventually re-united. Restoration was completed in 1994 with further work by
    Shelby specialist Rand E. Bailey in 2002.
    In the present owner’s collection since 2004, SFM5R102 has been carefully maintained in its original condition and exercised occasionally in track days and historic events. It was the feature car in
    the January 2005 issue of Texas Driver magazine. With a known history from new and an important record as one of only four R-models built by Shelby American in race-ready factory team car
    configuration, it is comprehensively documented including an all-important verification from SAAC 1965-66 Registrar Howard C. Pardee that its Ford chassis number coincides with the SFM5R102 chassis
    number assigned by Shelby American. It is believed still to be powered by the original engine provided by Shelby in 1965 and to have its original transmission and even the American Racing wheels,
    remarkable attributes in a race car so enthusiastically, frequently and successfully raced against top tier competition. It has been carefully restored by specialists in its 1965 SCCA National
    Championship configuration, including Shelby team Wimbledon white with blue stripes in deference to Carroll Shelby’s instructions.
    SFM5R102’s provenance includes some of the top names among Shelby collectors and historians including noted enthusiast Mr. Ken Eber. Some of them have owned it more than once, ample evidence of its
    historical importance and quality; knowledgeable collectors do not re-buy cars with uncertainties or “stories.” Of the 36 R-models built time and the vagaries of racing have taken their toll – only
    26 are known by SAAC to survive and SFM5R102 is at the pinnacle of importance and original configuration even in this elite company.
    A Shelby American team GT350R, three times invited to the ARRC, with unassailable history, impeccable provenance and a meticulous and accurate restoration, SFM5R102 is presented in race-ready
    condition as it appeared on the grid at the SCCA’s 1965 American Road Race of Champions at Daytona – before Walt Hane’s shoulder-check in the Daytona infield altered the front apron. There are only
    three other R-models like it, making this a fleeting chance to own one of the Shelby Mustangs that created the marque’s legendary reputation.
    This message has been scanned for viruses and
    dangerous content by MailScanner, and is
    believed to be clean.
  2. The car was owned by a person I know in the Dallas area, he was the one who
    put it up for auction. The restoration was very nice and the car was near
    perfect. We speculated about the price of this car before the auction.
    Lee
    66 # 869
    69 # 2055
  3. After the sale of this R Model for $990K, SAAC Board of Director, and R Model
    owner Howard Pardee was offered $1,000,000 for his car. I called him a few
    weeks ago to confirm this story, and in fact he said it was
    true...............he turned down the offer.
    Kenny
  4. I just popped in to my local ford dealer to look at a new truck. In the
    side showroom he had a couple of cars one being a 65 GT350. He had been
    offered 1 million for it and turned down. Saying that he apparently has
    wharehouse full of cars.
    regards
    > 108"
    > next three years.
    > hard work itself.
    > cooling air scoops.
    > tanks.
    > level.
    > Northeast Division.
    > coupes.
    > engine shop.
    > a barn-burner.
    > furious and
  5. NVSAAC
    NVSAAC Guest
    Here is an Article about the auction and R models.
    http://www.sportscarmarket.com/profiles/2006/July/Race/index.html
    Hopefully it works for those that are not subscribed to SCM.
    Jim Elsmore
    NVSAAC
    To: GT350HZ (AT) aol (DOT) com ; jonlee (AT) wt (DOT) net ; shelbymustang (AT) carmemories (DOT) com
    Sent: Thursday, June 08, 2006 2:46 AM
    Subject: Re: 900K 65 GT 350R car
    After the sale of this R Model for $990K, SAAC Board of Director, and R Model owner Howard Pardee was offered $1,000,000 for his car. I called him a few weeks ago to confirm this story, and in fact he said it was true...............he turned down the offer.
    Kenny
