Additional question on underbody paint
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by John Edwards, Apr 28, 2008.
  1. John Edwards
    John Edwards Member
    I had previously asked about the proper painting of the underbody of our 1968 Shelby and received the information for which I am greatly appreiciative. What I would like to know is whether there was a additional color sprayed over the red oxide primer in the rear wheel wells, or if they were left with the primer a factory undercoat.
  2. TLEA
    After the primer the body color went on so you will see overspray in the wells then (and this is for 68 NJ , different from other plants /years) sound deadener was shot in the well
    rshelby likes this.
  3. shlb69
    shlb69 Member
    send an email to me at shlb69@aol.com and I will send some photos of a orig 68 shelby bottom.
  4. Snakepit
    Since there was no great effort made to coat the entire rear wheel well with body color only the areas hit with body color (while painter applied the paint to the important areas) would receive overspray,
    So directly behind the fender lip generally would be bare metal or have some primer/sealer. out from that edge the overspray would start.
    Just think of the painter running the gun down the side of the car (front quarter panel to rear quarter panel) and the over spray pattern that would have created on the inner wheel well and exposed wheel well) Then picture the painter painting the entire wheel lip and the overspray that would produce
    Most of the time the amount of paint and the application is often pretty heavy - basically. just like the exterior of the car.
    OF course this is over the sound deadener applied earlier in the process ;)
    Here are a few pictures I hope will help explain
