C6 sorting problems
Discussion in 'Shelby Mustang List' started by Roger, Jun 22, 2005.
  1. Roger
    Roger Guest
    Hi gang,
    Ever since I had a schlocky outfit in Portland "overhaul" my '67 GT500's
    original C6, it hasn't worked right starting immediately upon reinstallation
    after the resto 3 years ago. I'd've been better off doing nothing but
    cleaning the outside of it. Finally I had my local hot rod genius come out
    to my shop and he installed a new high performance valve body. A short test
    drive this afternoon showed that some of the problems have been rectified,
    but not all.
    Before: It would shift out of 1st way too early, and skip (rev up briefly)
    going into 3rd.
    After: It shifts out of 1st at about the right time, but way more smoothly
    than when it was new or at any time up to the resto & overhaul. Also,
    there's still that split second of reving up as it is inbetween 2nd & 3rd.
    Any ideas? It's a Transgo, I think, valve body, new. I just checked the
    box, but I'm getting senile so I can't quite remember now that I've walked
    back here to the house. The tranny is good enough for crusing around, but
    it's not right yet.
    Thanks for the leads on the throttle actuator rod. I have one now from
    Mansfield and the next thing we're going to do is sort out the rich running
    carbs and work over the linkage operation. Then, after getting the voltage
    regulator calmed down a bit I think the car will be ready for its first
    somewhat long run...to the Portland Histrionics to meet new Shelby friends
    from this List.
    My Haggerty coverage including towing is paid up, and I'll have the Suburban
    in chase!
    Roger
    It's from Roger and Jane!
