Clutch Pedal Stick - 1966
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by 1972steve, Apr 10, 2008.
  1. 1972steve
    1972steve Active Member
    Guys-
    I always appreciate your tech feedback......
    I installed a Centerforce clutch in my 1966 and the clutch pedal will sometimes not return after releasing. Can a clutch pedal spring go bad? Should it be replaced or is there another alternative.
    Thank you.
    Steve
  2. s2ms
    s2ms Well-Known Member
    PNW
    Re: Clutch Pedal Stick
    Steve, I'm going on memory here and could be totally out of whack but I believe you have the opposite problem. The clutch pedal assist spring helps you get the pedal to the floor so it is in effect too strong for the built-in return forces in the diaphram type Centerforce clutch, that's why the pedal sometimes stays on the floor.
    I have a Centerforce dual friction clutch in my 66 and love it, never had this issue and the original clutch pedal assist spring is installed. I have however heard of this problem before and I believe the simple solution is to remove the clutch pedal assist spring.
    Dave
  3. 1972steve
    Dave-
    Is clutch pedal assist you mention the same thing as a clutch rod retacting spring. A spring that has a long connection shaft. I am looking at a diagram in National Parts Depot.
    Thanks for your help.
    Steve
  4. s2ms
    PNW
    Steve,
    The one I'm talking about is the heavy under-dash spring. In the NPD catalog I have it is part# 7534, named "Spring, Clutch Pedal".
    Dave
  5. zrayr
    zrayr Well-Known Member
    TX
    it's not that easy to remove, but once it's out, you won't have that problem again.
    Z. Ray
  6. lnevill
    lnevill Active Member
    Idaho
    I had the same issue on my 70 boss with a diaphram clutch. The large spring under the dash actually helps in both directions. Once it is past the center point, it helps depress the clutch and once it returns past the center point, it helps hold the pedal up (the spring is compressed the most at the center point). The problem is that with a diaprham clutch that is so easy to push, it never get's back past the center point. You need to remove the spring as mentioned. In order to do this, you need to remove the pedal, or at least slide it off the mounting rod so the spring can be removed. It is a bear to do with the dash and seats in, but can be done. I added another spring in the engine compartment to keep the pedal up.
    Hope this helps
    Lee
  7. zrayr
    TX
    you can just remove the clutch petal stop bracket . It contacts the petal as it reaches it's upper range of travel. With it removed, move the petal up as far as can go. This will take all or most of the tension off the spring so it can be removed easier.
    Z. Ray
  8. 1972steve
    This is what I love about this forum. Experience and the willing to share knowledge.
    Thank you all.;)
    Warm regards,
    Steve
