Just wanted to introduce my business, Retro Lane Autoworks. We are a dealer/builder for Shell Valley replicas which we carry their full line of cars as well as Oze Hot Rods. We also offer a full restoration services on classics and muscle cars. Anything from a small patch job to a full restoration, quality and pride of craftsmanship is always there. We currently have '67 Cobra 427 complete kit in stock. This kit is the full kit with every nut and bolt needed to build the car. All you need to supply is the engine/trans/driveshaft and a set of wheels. Pre-assembled on a rolling chassis for easy transport. We can build this one for you as well with or without the drivetrain so you can just get it in, turn the key, and cruise the boulevard. Kit price: $24,600 Turnkey minus: $35,500 Turnkey: starts at $45,000 For complete specs and more information on this replica as well as finished photos of what it would look like complete go to www.retrolaneautoworks.com and see the replica cars section. Made by on of the best Cobra replica manufacturers with over 35 years of manufacturering Cobra's this is the latest version with new improvements. The best improvement is the addition of a wider footwell with a 4" drop box built in for more legroom and comfort for taller and larger drivers. This is the only replica to feature this option! This Cobra is setup to accept a 302-351 Ford engine and a manual or auto trans. Comes with ceramic coated headers and side exhaust as well! Specifications: The Body: This beast has an aerodynamic, high quality state-of-the-art roadster body. This classic comes with smooth, sandable gel-coat finish. It is totally reinforced with fiberglass matte, resin and chopped glass. All bodies have Kevlar™ and steel molded into the critical stress points. The body comes with all divider panels installed, doors, hood and trunk installed and steel cowl hoop with all hinges installed (working doors, hood and trunk). The body is pre-mounted to the frame for proper fit. The Chasis: • Rectangular powder coated tube frame with all suspension mounted in place • Small block Ford motor mount brackets welded in place • Universal transmission mount included • Cowl hoop with door hinges installed • Body pre-positioned and installed • Body mounting kit with weather-strip included Front Suspension: • New tubular upper and lower A-arms, installed • New spindles, installed • New rack and pinion steering complete with tie rods and bushings, installed(power rack available) • New 5 bolt 11” rotors, installed • All bearings, seals and dust caps • Rebuilt brake calipers complete with caliper brackets • Aluminum QA1 coilover shocks, adjustable with springs, installed • Front brake hoses with fluid bolts and washers Rear Suspension: • 4 polished aluminum radius arms, installed • Aluminum QA1 coilover shocks, adjustable with springs, installed • Ford 9” rear end with new Moser axles and used third member, installed with 3.50 locker gears • New 5 bolt 11” rotors • Standard disc brake package includes brake calipers and caliper mounting brackets • Rear brake hoses with fluid bolts and washers and splitter block Other Items Included: • Side exhaust pipes (ceramic coated) • Headers (Ford) (ceramic coated) • Brake line kit • 3/8” fuel line kit • Complete steering column assembly with steering wheel • 16 gallon steel fuel tank • LeMans style gas cap with filler hose • Gas pedal assembly complete with linkage • Brake pedal assembly with two master cylinders and balance bar • Clutch option • Complete windshield assembly, chrome plated brass and 2 surround plates • Single roll bar with mounting kit (chrome) • New aluminum radiator complete with mounting brackets • Wiring harness complete with prewired switches • All handles and latches for doors, hood and trunk • Hood prop • Complete 6 gauge set (VDO™) • 16 inch high efficiency electric fan • Complete light package • Side racing mirror and rear view mirror • Stainless steel side vent louvers • Bumper mounting kit • Quickjack bumpers For more information or to see the kit in person just contact us: Phone: 973-427-5800 E-Mail: info@retrolaneautoworks.com Web Site: www.retrolaneautoworks.com Retro Lane Autoworks 275 Wagaraw Road Hawthorne, NJ 07506
