Front end squeaks
Discussion in 'Shelby Mustang List' started by Ronald. Robertson, May 29, 2006.
  1. Need some ideas on how to get rid of front end squeaks in the 1969. I suspect the brand new (350 miles on them) upper control arms may be the culprit. Have had them greased twice. Problem is intermittent. First squeaked about 3 weeks ago - greased them again. All O.K. until last Saturday night and both sides squeak like mad. Any suggestions appreciated.
    Ron
  2. Tom Kubler
    Tom Kubler Guest
    Could it be the rubber insulators in the sring saddles? maybe some of that PFTE lubricating spray on them...
    "Ronald. Robertson" <ronald.robertson (AT) sympatico (DOT) ca> wrote: Need some ideas on how to get rid of front end squeaks in the 1969. I suspect the brand new (350 miles on them) upper control arms may be the culprit. Have had them greased twice. Problem is intermittent. First squeaked about 3 weeks ago - greased them again. All O.K. until last Saturday night and both sides squeak like mad. Any suggestions appreciated.
    Ron
  3. Bill Wells
    Bill Wells Guest
    could be a long shot, and be something else..i spray WD-40 on all
    undercarriage bushings on my 3 toy cars and 95% of the time the mysterious
    squeaks disappear....if the cars see excessive rain, i spray WD-40 on them
    again, otherwise about every 90 -120 days for the heck of it. bill, motown
    -----Original Message-----
    From: Tom Kubler [mailto:tjinsa (AT) yahoo (DOT) com]
    Sent: Monday, May 29, 2006 5:00 PM
    To: Shelby Mustang List
    Subject: Re: Front end squeaks
    Ron
  4. STAN SIMM
    STAN SIMM Guest
    Ron-Front sway bar bushings will squeek, too. Run the car up on some good ramps or a drive-on lift and get someone to bounce it up and down while you listen. A length of rubber hose used like a stethoscope can help isolate it.
    Regards, Stan
    To: Shelby Mustang
    Sent: Monday, May 29, 2006 2:56 PM
    Subject: Front end squeaks
    Ron
  5. Stan, Bill and Tom:
    Thank you for the suggestions. Will try that tomorrow and let you know how the suggestions work out.
    Thanks again. The neighbors will be impressed.
    Ron
    To: Ronald. Robertson ; Shelby Mustang
    Sent: Monday, May 29, 2006 5:30 PM
    Regards, Stan
    To: Shelby Mustang
    Ron
  6. I just replaced allt he bushings on my 69 with Neopream bushings. I then
    put around 500 miles on them and had them re tweaked and now no sounds
    coming from anywhere. WD works pretty good but doesn't last too long and
    I am not sure how good it is for the rubber over time. Good luck but I
    would check into the whole front end bush replacement.
    > Ron
  7. Fwd: Front end squeaks
    5/29/2006
    Ron,
    Sorry to spoil your party: But: Most likely, you will need to remove the A
    Frame Shafts and
    repack with grease again. Pumping grease from the end fittings, usually
    doesn't work.
    We have seen, brand new ball joints, dry to the bone also.
    Pete Geisler
    Orlando Mustang
    407 688 1966
    In a message dated 5/29/2006 2:57:31 PM Eastern Standard Time,
    ronald.robertson (AT) sympatico (DOT) ca writes:
    Ron
  8. Pete is probably correct, I went through two sets of upper arms on my 1966
    before I was satisfied. Replaced many other parts because I couldn't figure
    out the problem.
    Lee
    66 # 869
    69 # 2055
  9. Thanks Randall. Appreciate the input.
    Ron
    To: "Tom Kubler" <tjinsa (AT) yahoo (DOT) com>
    Cc: "Shelby Mustang List" <shelbymustang (AT) carmemories (DOT) com>
    Sent: Monday, May 29, 2006 6:02 PM
    > Randall
    >> about
    >> Ron
  10. Guest
    Guest Guest
    Re: Re: Front end squeaks
    When I put poly sway bar bushings in one, I drill a small hole through the bracket and through the bushing. Screw a small grease fitting into the hole and you can lubricate the sway bar bushings. Most of the squeeks from poly bushings can be lubricated away. SEE Y'ALL
    > From: randall.paul (AT) randallpaul (DOT) com
    > Date: 2006/05/29 Mon PM 06:02:54 EDT
    > CC: "Shelby Mustang List" <shelbymustang (AT) carmemories (DOT) com>
    > Randall
    > > Ron
  11. In a message dated 5/29/06 11:57:23, ronald.robertson (AT) sympatico (DOT) ca writes:
    << Need some ideas on how to get rid of front end squeaks in the 1969. I
    sides squeak like mad. Any suggestions appreciated. >>
    >>>At the risk of asking the obvious, do they have stock rubber or new poly
    bushings?
    Poly bushings squeak like mad unless they are properly lubricated, and grease
    is NOT the proper lube. I find that silver anti-seize works best.
  12. g adams
    g adams Guest
    I had a bad squeak that turned out to be the curved
    part of the sway bar rubbing on the frame. My car has
    lowered a-arms and global west uppers. The frame has
    a small notch from the factory but the alignment
    changed with the lowering. I just extended the notch
    to the rear to clear.
    Greg
    www.uniquemotorcars.net
    > bushings?
    > Mike
    __________________________________________________
    Do You Yahoo!?
    Tired of spam? Yahoo! Mail has the best spam protection around
    http://mail.yahoo.com
