I've got a T5 in my 66 289 Coupe and it is just amazing! You can drive it around town with the first 4 speeds and then stretch it's legs on the highway with the 5th gear. I have gotten 25 mpg cruising along at 70-ish. Carl --- Cevon Mclean <cmclean@rbhnrc.usda.gov> wrote: > From: "Cevon Mclean" <cmclean@rbhnrc.usda.gov> > To: shelbymustang@carmemories.com > Date: Tue, 26 Jul 2005 10:41:36 -0500 > Subject: 68 GT350 5-Sp Swap Awsome! > > Hey Guys, > Just wanted to let you know if you were thinking of swaping a > 5sp > into a 68gt350, dont hesitate. Its the best of 2 worlds..I > have 3:89 > gears and put a New Tremec TKO500 5-sp into the car, used the > same driveshaft, but changed the yoke. Ordered the shorter > input > shaft and used my old bell houseing and clutch assembly. The > trans was a bolt in. I used the aftermarket trans mount but > modified > it so the trans was 1/8 inch from the top of the tunnel. > Installed the > aftermarket stock looking shifter and 4sp knob. Installed the > console, cut it 1/8 inch forward a tad and had to trim the > right > forward shifter opening in the tunnel about 1/8 inch to clear > 5th gear. > I also had to make a alumium spacer to move the shifter 1/2 to > the > left and 1" to the rear to center the shifter in the console. > Wasent > too bad. Sounds worse than it was...Looks stock and im the > only > one who knows it has another gear!..but I love haveing the > 3:89 > gears in the first 4 speeds and then 5th gear!. 60mph @ > 1800rpm > and 80mph @ 2500...!!..talk about less wear and tear..also > great > gas milage!..All for about $2,000...just parts...Of course I > saved the > stock top loader and shifter. Its great cruiseing at 2000rpm > with the > Air ON!...Can you say "ICE COLD A/C..!!...".... > Just thought Id pass on the info... > > If interested I got everthing from TTC Eric Swarr in > Collegeville PA. > 610.489.4029 Great Guy, Big Help. > > Cevon... > > > ____________________________________________________ Start your day with Yahoo! - make it your home page http://www.yahoo.com/r/hs
Re: 68 GT350 5-Sp Swap Awsome! Ditto here! I've got a T-5 conversion in 6S1467 and you've got to look hard to see it but it's a delight to drive. Of course, I've saved the C-4 and all the hardware that came off. Regards, Stan ----- Original Message ----- From: "Carl McNew" <indy_carl50@yahoo.com> To: "Shelby list" <shelbymustang@carmemories.com> Sent: Tuesday, July 26, 2005 2:43 PM Subject: Fwd: 68 GT350 5-Sp Swap Awsome! > I've got a T5 in my 66 289 Coupe and it is just amazing! You > can drive it around town with the first 4 speeds and then > stretch it's legs on the highway with the 5th gear. I have > gotten 25 mpg cruising along at 70-ish. > > Carl > > --- Cevon Mclean <cmclean@rbhnrc.usda.gov> wrote: > > > From: "Cevon Mclean" <cmclean@rbhnrc.usda.gov> > > To: shelbymustang@carmemories.com > > Date: Tue, 26 Jul 2005 10:41:36 -0500 > > Subject: 68 GT350 5-Sp Swap Awsome! > > > > Hey Guys, > > Just wanted to let you know if you were thinking of swaping a > > 5sp > > into a 68gt350, dont hesitate. Its the best of 2 worlds..I > > have 3:89 > > gears and put a New Tremec TKO500 5-sp into the car, used the > > same driveshaft, but changed the yoke. Ordered the shorter > > input > > shaft and used my old bell houseing and clutch assembly. The > > trans was a bolt in. I used the aftermarket trans mount but > > modified > > it so the trans was 1/8 inch from the top of the tunnel. > > Installed the > > aftermarket stock looking shifter and 4sp knob. Installed the > > console, cut it 1/8 inch forward a tad and had to trim the > > right > > forward shifter opening in the tunnel about 1/8 inch to clear > > 5th gear. > > I also had to make a alumium spacer to move the shifter 1/2 to > > the > > left and 1" to the rear to center the shifter in the console. > > Wasent > > too bad. Sounds worse than it was...Looks stock and im the > > only > > one who knows it has another gear!..but I love haveing the > > 3:89 > > gears in the first 4 speeds and then 5th gear!. 60mph @ > > 1800rpm > > and 80mph @ 2500...!!..talk about less wear and tear..also > > great > > gas milage!..All for about $2,000...just parts...Of course I > > saved the > > stock top loader and shifter. Its great cruiseing at 2000rpm > > with the > > Air ON!...Can you say "ICE COLD A/C..!!...".... > > Just thought Id pass on the info... > > > > If interested I got everthing from TTC Eric Swarr in > > Collegeville PA. > > 610.489.4029 Great Guy, Big Help. > > > > Cevon... > > > > > > > > > > > ____________________________________________________ > Start your day with Yahoo! - make it your home page > http://www.yahoo.com/r/hs >
