garage/ cooler find - GT350
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by FORDFREAK05, Jan 3, 2008.
  1. FORDFREAK05
    FORDFREAK05 Member
    It Is Very Fixable, Yes It Needs It From The Coul Back And 3 Inches Up...in Some Spots. But It Is What It Is..,, And Done Properly,, It Will Alwas Be The Real Deal With Matching# I Belive..
  2. tesgt350
    SOOOOOOOO.......when do you become the proud PaPa? :thumbsup:
  3. FORDFREAK05
    FORDFREAK05 Member
    It Going To Take Me A Min. To Scrape Up Some Cash..
    He Wants Top Dollar For It... He Is Going To Look At A 97 Sho I Picked Up V8 Police Intersepter... There Cool Too.. Sounds Bad..,, I Dont Know Ill Have To E Bay My Life. ...at Least I Have Some Extra Time To Work On It...
  4. SFM6S2015
    SFM6S2015 Well-Known Member
    You sir are a very brave man. I once passed on a very rusty 65 for $35k. Today I wish I would have bought it. Good luck!!!!!!!!!
    Larry
  5. 65gtfastback
    @ Nashville
    you have been bitten and now have Shelby fever. there is no cure. Get a Lincoln welder some die grinders and a rusty 6 cyl coupe to practice on...
  6. Coralsnake
    I agree that car would have to be under $20k to make it worth it....you said, "price wars are on?" Prices haven't been this low for ten years...so don't feel any pressure. It may be real, but the only way it can have any value is to have it done it right. Judging from the poor storage, I would say $75,000 would be a good start!
  7. FORDFREAK05
    FORDFREAK05 Member
    Im Good At Welding Patch Pannels., I First Did My Powerstrokes Ext Cab Corner. Then Tore Into A 1971 Chevelle To Really Practice On I Fixed That Rusty Turd And Got 3 More Chevelles For Doing It. 1 Ss..
    Yes I Need A New Welder I Had A Bomb Snap On Welder Untill The Computer Went Out. Now I Need A New One...
    We Will See How It Works Out
  8. FORDFREAK05
    FORDFREAK05 Member
    Price Wars ..,, As In Im Trying To Get It Down A Bit . I Thought It Was Worth 15,000 Tops And He Wants A Lot More...
  9. 65gtfastback
    @ Nashville
    I would poke around under that car for 30 minutes before I made the final offer.
  10. FORDFREAK05
    FORDFREAK05 Member
    Dont Need To Poke I Can See The Ground Thrugh The Floors. The Seats Arnt That Bad Though..it Will Need All Of The Floor And Rear Subframs, Frame Rail However You Put It..lots Of Mesuring And Time..
    It Needs A Nice Solid Doner Car That I Can Pull Apart ... Spot Weld By Spot Weld, And So On.. Other People Do It All The Time...
  11. FORDFREAK05
    FORDFREAK05 Member
    He Wants 25000 For It.. A Little Steep I Think
  12. tesgt350
    $25K is Top Dollar, BUT, I would bet you could find many takers here.
  13. 65gtfastback
    @ Nashville
    Depends on what you're seeing the ground through. If its floor boards its no big deal. If its door jams and once galvanized rocker panels and rear torque boxes that are gone you need to run. Need to find out why it looks like its sagging in one picture.
  14. Jerry_Moss
    Jerry_Moss Well-Known Member
    Germany/Bavaria
    Hey give it a try! Lots of work but most of the parts are avalible
    today. Or just buy a fastback and convert it incl VIN :eek:
    Most of the car won´t be original anyways so,.....
    Good luck
    Jerry
  15. FORDFREAK05
    FORDFREAK05 Member
    The Rockers Are Solid.. Surprize.. Torque Box Proububly Gone..
  16. FORDFREAK05
    FORDFREAK05 Member
    I Can Get A Fastback For Parts Ans Separate The Body.. From The Floor... I Have Seen This Done A Couple Of Times...,, As Far As A Rebody.,, Then Alot Of These Cars That Are Being Restored Are Re Bodys... It Just Depends On How Good You Do It As Far A A Vin Swap That Would Be Fraud, Ab=nd Is Highly Illiagal...
  17. shelby6t5
    shelby6t5 Well-Known Member
    Wow....do not post any #'s on it - in my opinion it looks like a candidate for a re-body. "10k and tow it away", but more likely a "fork lift and a flatbed".
    Sad to see.
  18. GT350-66s
    GT350-66s Member
    Pittsburgh PA.
    My advice for what it's worth, buy it at 25K. Take the time to get all the parts you can with it. Some, like the fan did not look hipo, but get EVERYTHING you can to offset some of your expenses. When you start throwing cash at hard to get hipo or Shelby parts you will appreciate every dime you can get back.
    Also, document the restoration with recipts and pics. Do everything you can to save the shell. If you cant save the inner fenders, at least keep whats left to prove originality. We all know of cars that came from worse, but in my eyes if you show how bad it was to begin with and what you did to fix and or replace each piece, it means everything.
    Very interesting car. Good luck, Gary
  19. FORDFREAK05
    FORDFREAK05 Member
    The Shell And Front Innerfender Wells Are Fine.. Its Just The Whole Floor...... And As Far As The Hood Why Is It Junk ..,, I Am Sure You Can Reframe It... It Is Just A Giant Model.. Thats All....
  20. FORDFREAK05
    FORDFREAK05 Member
    Also There Will Be Some Bracing In The Inside...also... I Need A Real Solid Fastback To Tear Appart...... For The Doner Pieces
