I purchased my 2007 Shelby GT500 when it had 12,000 miles on it and was 1 year old. I keep it covered in the garage when I’m not using it. Currently has 21,000 miles on it. I noticed that the hood was starting to rust under the paint, apparently a month before the warranty was up. I had no idea that the warranty was up due to the fact that these cars normally have a 3 year warranty and it wasn’t even fully into it’s 2nd year. When I brought it in for service, I got an oil change and I let the service manager know about the rust. The dealership told me that the warranty had expired a month ago and that Ford wouldn’t cover the repair. I ten contacted the Ford headquarters numerous times, only to be cast aside ad told that it “wasn’t their problem.” I think its ridiculous to buy a $50,000 car and when it has a factory defect-which a Shelby expert told me the rust was-and the same thing has been a problem with Ford products in the passed (the same rusting happened to my 2004 Expedition’s aluminum hood and to my son’s 2006 Mustang). Ford told me that it wasn’t covered and they aren’t gonna fix it. Since it hasn’t rusted through and developed a hole, Ford claims that they aren’t responsible. Buyers beware, not only in purchasing newer Shelbys but Mustangs in general, due to mine and my son’s problem with rusting.
If you bought the car used how can you be sure that the car was not damaged and had a repainted hood. Does sound like a paint problem. I have not heard of this problem and my wife drives an 05 Expedition with over 70k miles with no "rust" issues. Don't forget that I live in Michigan where rock salt is used heavily and most of our Expedition miles are winter miles. Also, my wife's summer car is an 06 Mustang GT with no hood problems at all. I guess we have similar cars only I have none of your issues.
Here you go, there are quite a few 2006 models with the problem some 2007s and some 2008s. Your hood was contaminated at the point of manufacture by iron particles, iron particles cause corrosion on aluminum. Not all hoods were contaminated. This type of corrosion damage has nothing to do with normal rust warranty but is a manufacturing error. Here is the TSB: TSB 06-25-15 - ALUMINUM BODY PANELS - CORROSION - SERVICE TIP Publication Date: December 11, 2006 FORD: 2000-2007 Crown Victoria, Taurus 2005-2006 Ford GT 2005-2007 Mustang 2000-2003 Ranger 2000-2007 Expedition 2002-2007 Explorer 2004-2007 F-150 2007 Explorer Sport Trac LINCOLN: 2000-2006 Lincoln LS 2000-2007 Town Car, Navigator MERCURY: 2000-2007 Grand Marquis, Sable This article supersedes TSB 04-25-1 to update the vehicle model years. ISSUE: Some vehicles may exhibit a bubbling or blistering under the paint on aluminum body parts. This is due to iron contamination of the aluminum panel. ACTION: This TSB provides service tips and procedures, outlining methods to properly prepare and protect aluminum body parts from cross contamination. BACKGROUND Ford's Scientific Research Laboratory has performed a number of tests on vehicle body parts returned for corrosion related concerns. Testing has revealed that the aluminum corrosion was caused by iron particles working their way into the aluminum body part, prior to it being painted. SERVICE TIPS AND PROCEDURE When repairing a vehicle for corrosion or collision damage, it is essential that extreme care be taken to cover and protect all aluminum parts to prevent cross metal contamination. Areas in a shop where metal work is performed should be sectioned off, using at the very least curtain walls, to prevent metal dust migration. Cross contamination can also occur through the use of metal working tools (hammers, dolly's, picks, grinding wheels, etc.). Tools used for aluminum repairs should be kept separate, and not used to repair other metals. Wire brushes used on aluminum should be made of stainless steel. NOTE: THIS PROCEDURE SHOULD ONLY BE USED ON NON-PERFORATED METAL. REVIEW WARRANTY AND POLICY MANUAL FOR VEHICLE WITH PERFORATED METAL. NOTE: READ THIS PROCEDURE COMPLETELY BEFORE PERFORMING ANY SERVICE. 1. Corrosion should be removed by blasting. Use an aggressive blasting material, such as acrylic (salt grain size). 2. Use a DA sander with 180 grit paper backed abrasive. Only sand and featheredge the damaged area. 3. Mix and apply Ford approved epoxy primer, per the manufacturer's label instructions. Bake at 140° F (60° C), or use an infra-red lamp for curing. 4. If necessary, mix and apply two-part polyester filler to a slight over crown. Allow polyester filler to cure 20-30 minutes, or mix and apply spray polyester filler two-three (2-3) coats as necessary. Allow to cure per manufacturer's label instructions. 5. Hand-sand the repair area with 80 grit sand paper to remove excess filler. 6. Finish-sand the repair area with 400 grit sand paper. 7. Mix and apply Ford approved primer/surfacer per manufacturer's label instructions. Bake at 140° F (60° C) or use infra-red lamp for curing. 8. Sand the primer/surfacer with 400-600 grit to level the surface. 9. The next two steps are wet-on-wet. Mix and apply to hiding Ford recommended basecoat material per manufacturer's label instructions. Allow to flash. 10. Mix and apply two (2) coats (2 mils minimum) of Ford approved clearcoat per manufacturer's label instructions. Allow flash time. Finish bake at 140° F (60° C). WARRANTY STATUS:
