Help--need recommendations for brake pads & shoes
Discussion in 'Shelby Mustang List' started by DLen1261@aol.com, Feb 16, 2006.
  1. I'm replacing the brakes on my 65 GT350 & need recommendations for "locally
    available" brands (& their individual product lines/friction materials) of pads
    & shoes.
    The car sees limited street and (at novice group or slower speeds) "track
    day" use; my primary concern for the immediate future is safety (especially
    safety & dependability on-track), not NOS/concours stuff.
    Anything decent available from the "auto parts" chains? NAPA?
    thanks in advance,
    Dave
  2. Colin Comer
    Colin Comer Guest
    Dave,
    Not a locally available brand, but you can order great pads from Portefield. They will make pads in any compound you want - I think I use the "R4S" compound in my 65/66 cars and it works great.
    http://www.porterfield-brakes.com/pads.html
    Good luck,
    Colin
    To: shelbymustang (AT) carmemories (DOT) com ; norcal-saac (AT) yahoogroups (DOT) com
    Sent: Thursday, February 16, 2006 4:27 PM
    Subject: Help--need recommendations for brake pads & shoes
    I'm replacing the brakes on my 65 GT350 & need recommendations for "locally available" brands (& their individual product lines/friction materials) of pads & shoes.
    The car sees limited street and (at novice group or slower speeds) "track day" use; my primary concern for the immediate future is safety (especially safety & dependability on-track), not NOS/concours stuff.
    thanks in advance,
    Dave
  3. STAN SIMM
    STAN SIMM Guest
    Dave-
    Even tho you're not going to "push the envelope" so to speak, I heartily recommend that, if you're going to do any track time at all, you need all the braking efficiency you can get. Check out a company by the name of Praisedyno at www.praisedyno.com. They have the correct size pads and shoes(you may need to contact them directly for the right p/ns). I don't think you're gonna be satisfied with street stuff and, considering the labor involved, it's worth putting on the up-graded material.
    Regards, Stan
    Sent: Thursday, February 16, 2006 5:27 PM
    thanks in advance,
    Dave
  4. STAN SIMM
    STAN SIMM Guest
    Correction to the web-address:
    www.praisedynobrake.com
    Sorry 'bout that!
    thanks in advance,
    Dave
  5. Do they produce alot of brake dust? I like my rims to stay clean - you know bling bling. The ones I have on now make a ton of brake dust for mine.
    jon
    Quoting Colin Comer <colin (AT) colinsclassicauto (DOT) com>:
    - Dave,
    - Not a locally available brand, but you can order great pads from Portefield. They will make pads in any compound you want - I think I use the "R4S" compound in my 65/66 cars and it works great.
    - http://www.porterfield-brakes.com/pads.html
    - Good luck,
    - Colin
    - ----- Original Message -----
    - To: shelbymustang (AT) carmemories (DOT) com ; norcal-saac (AT) yahoogroups (DOT) com
    - Sent: Thursday, February 16, 2006 4:27 PM
    - Subject: Help--need recommendations for brake pads & shoes
    - I'm replacing the brakes on my 65 GT350 & need recommendations for "locally available" brands (& their individual product lines/friction materials) of pads & shoes.
    - The car sees limited street and (at novice group or slower speeds) "track day" use; my primary concern for the immediate future is safety (especially safety & dependability on-track), not
    - NOS/concours stuff.
    - Anything decent available from the "auto parts" chains? NAPA?
    - thanks in advance,
    - Dave
    > & shoes.
    I do many track days with many different cars. I have tried lots of brake
    pads. Given what you are asking, I would probably go with the Performance
    Friction Carbon Metalics. Autozone used to have these with a lifetime
    warranty, that they stood behind well. You bought them once and they
    replaced them whenever they ran out. I put 3-4 sets of pads on one of my
    cars. They also had the Z-rated pad. I would probably suffest the standard
    Carbon pad. If you decide they are a little weak for your track duty, get
    the Z-rated pads. The Z-rated ones produce a little more brake dust.
    If these don't work out, I might suggest the Hawk HPS pads, but you
    usually have to get them mail order. Tirerack.com is usually the best
    place to get these.
    Calvin
    http://svsaac.com/ <<--our Shelby local club
    http://www.racecarstuff.com <<--my blog
    http://motors.search.ebay.com/_W0QQsassZcalvin767 <<--my ebay stuff
  7. Colin Comer
    Colin Comer Guest
    Not a ton of dust (no more than OE), but, if you use them on the track I
    have never seen a pad that doesn't make a mess. I'd rather clean brake dust
    than repair sheetmetal ;)
    Colin
    To: "Shelby List" <shelbymustang (AT) carmemories (DOT) com>
    Sent: Thursday, February 16, 2006 7:10 PM
    Subject: Re: Help--need recommendations for brake pads & shoes
    > mine.
    > jon
    > - Dave,
    > - Good luck,
    > - Colin
    > - From: DLen1261 (AT) aol (DOT) com
    > - Dave
  8. I guess Im asking too much huh? ha
    Everytime I go out, I have to take a towel and wipe off the brake dust build up.
    jon
    - Not a ton of dust (no more than OE), but, if you use them on the track I
    - have never seen a pad that doesn't make a mess. I'd rather clean brake dust
    - than repair sheetmetal ;)
    - Colin
    - To: "Shelby List" <shelbymustang (AT) carmemories (DOT) com>
    - Sent: Thursday, February 16, 2006 7:10 PM
    - Subject: Re: Help--need recommendations for brake pads & shoes
    - > Do they produce alot of brake dust? I like my rims to stay clean - you
    - > know bling bling. The ones I have on now make a ton of brake dust for
    - > mine.
    - > jon
    - > Quoting Colin Comer <colin (AT) colinsclassicauto (DOT) com>:
    - > - Dave,
    - > - Not a locally available brand, but you can order great pads from
    - > Portefield. They will make pads in any compound you want - I think I use
    - > the "R4S" compound in my 65/66 cars and it works great.
    - > - http://www.porterfield-brakes.com/pads.html
    - > - Good luck,
    - > - Colin
    - > - ----- Original Message -----
    - > - From: DLen1261 (AT) aol (DOT) com
    - > - To: shelbymustang (AT) carmemories (DOT) com ; norcal-saac (AT) yahoogroups (DOT) com
    - > - Sent: Thursday, February 16, 2006 4:27 PM
    - > - Subject: Help--need recommendations for brake pads & shoes
    - > - I'm replacing the brakes on my 65 GT350 & need recommendations for
    - > "locally available" brands (& their individual product lines/friction
    - > materials) of pads & shoes.
    - > - The car sees limited street and (at novice group or slower speeds)
    - > "track day" use; my primary concern for the immediate future is safety
    - > (especially safety & dependability on-track), not
    - > - NOS/concours stuff.
    - > - Anything decent available from the "auto parts" chains? NAPA?
    - > - thanks in advance,
    - > - Dave
  9. Colin Comer
    Colin Comer Guest
    If you have to wipe your wheels after street driving, you DEFINITELY have
    the wrong pads! If you aren't racing, I know SSBS and others make "low dust"
    pads that may work better for you also.
    Or maybe you just care too much about the Bling? LOL
    Colin
    Sent: Friday, February 17, 2006 11:34 AM
    > build up.
    > jon
    > dust
    > - Colin
    > - From: <jonlee (AT) wt (DOT) net>
    > you
    > - > mine.
    > - > jon
    > - > - Dave,
    > use
    > - > - Good luck,
    > - > - Colin
    > - > - Dave
  10. HUM...Im will have to try SSBS pads after my old ones wear out.
    thanks
    jon
    - If you have to wipe your wheels after street driving, you DEFINITELY have
    - the wrong pads! If you aren't racing, I know SSBS and others make "low dust"
    - pads that may work better for you also.
    - Or maybe you just care too much about the Bling? LOL
    - Colin
    - Sent: Friday, February 17, 2006 11:34 AM
    - > I guess Im asking too much huh? ha
    - > Everytime I go out, I have to take a towel and wipe off the brake dust
    - > build up.
    - > jon
    - > - Not a ton of dust (no more than OE), but, if you use them on the track I
    - > - have never seen a pad that doesn't make a mess. I'd rather clean brake
    - > dust
    - > - than repair sheetmetal ;)
    - > - Colin
    - > - From: <jonlee (AT) wt (DOT) net>
    - > - To: "Shelby List" <shelbymustang (AT) carmemories (DOT) com>
    - > - Sent: Thursday, February 16, 2006 7:10 PM
    - > - Subject: Re: Help--need recommendations for brake pads & shoes
    - > - > Do they produce alot of brake dust? I like my rims to stay clean -
    - > you
    - > - > know bling bling. The ones I have on now make a ton of brake dust for
    - > - > mine.
    - > - > jon
    - > - > Quoting Colin Comer <colin (AT) colinsclassicauto (DOT) com>:
    - > - > - Dave,
    - > - > - Not a locally available brand, but you can order great pads from
    - > - > Portefield. They will make pads in any compound you want - I think I
    - > use
    - > - > the "R4S" compound in my 65/66 cars and it works great.
    - > - > - http://www.porterfield-brakes.com/pads.html
    - > - > - Good luck,
    - > - > - Colin
    - > - > - ----- Original Message -----
    - > - > - From: DLen1261 (AT) aol (DOT) com
    - > - > - To: shelbymustang (AT) carmemories (DOT) com ; norcal-saac (AT) yahoogroups (DOT) com
    - > - > - Sent: Thursday, February 16, 2006 4:27 PM
    - > - > - Subject: Help--need recommendations for brake pads & shoes
    - > - > - I'm replacing the brakes on my 65 GT350 & need recommendations for
    - > - > "locally available" brands (& their individual product lines/friction
    - > - > materials) of pads & shoes.
    - > - > - The car sees limited street and (at novice group or slower speeds)
    - > - > "track day" use; my primary concern for the immediate future is safety
    - > - > (especially safety & dependability on-track), not
    - > - > - NOS/concours stuff.
    - > - > - Anything decent available from the "auto parts" chains? NAPA?
    - > - > - thanks in advance,
    - > - > - Dave
  11. HUM...Im will have to try SSBS pads after my old ones wear out.
    thanks
    jon
    - Colin
    - > build up.
    - > jon
    - > dust
    - > - Colin
    - > you
    - > - > mine.
    - > - > jon
    - > - > - Dave,
    - > use
    - > - > - Colin
    - > - > - Dave
  12. I am running the SSBC pads and they have seemed to work well. for me it is
    the street and a bit of autocross. of course they way I drive on the street is
    not too far from autocross.
    I have been wondering about the ceramic pads. what do you guys think>
    also I thought I had heard of something that you spray on your wheels to
    keep the brake dust from sticking. anybody heard anything or is it just more BS
    bob
    I use Macguiars Spray Wax. Before each track event I spray the stuff on
    and apply it like normal wax. I can take and air hose and blow 99% of the
    brake dust away (and some of my brake pads generate very heavy brake dust)
    the remaining 1% will wipe away with a cleaning cloth. It also makes the
    wheels look pretty good.
    Calvin
    http://svsaac.com/ <<--our local Shelby club
  14. Carbon kevlar for me from Cobra Automotive.
    Rick
    To: jonlee (AT) wt (DOT) net ; shelbymustang (AT) carmemories (DOT) com
    Sent: Friday, February 17, 2006 2:41 PM
    I am running the SSBC pads and they have seemed to work well. for me it is the street and a bit of autocross. of course they way I drive on the street is not too far from autocross.
    also I thought I had heard of something that you spray on your wheels to keep the brake dust from sticking. anybody heard anything or is it just more BS
    bob
  15. Jeff Fox
    Jeff Fox Guest
    I too use the SSBC pads and the brake dust doesn't seem to be too bad.
    bob
  16. I made a large quantity purchase of that brand of pad if anyone needs any
    >From: jonlee (AT) wt (DOT) net
    >To: Shelby List <shelbymustang (AT) carmemories (DOT) com>
    >Date: Fri, 17 Feb 2006 12:05:40 -0600
    >thanks
    >jon
    >dust"
    >- Colin
    >- > build up.
    >- > jon
    >track I
    >brake
    >- > dust
    >- > - Colin
    >- > you
    >for
    >- > - > mine.
    >- > - > jon
    >- > - > - Dave,
    >I
    >- > use
    >- > - > - Colin
    >for
    >lines/friction
    >speeds)
    >safety
    >- > - > - Dave
    _________________________________________________________________
    Don’t just search. Find. Check out the new MSN Search!
    http://search.msn.click-url.com/go/onm00200636ave/direct/01/
