Hopefully changing the subject
Discussion in 'Shelby Mustang List' started by Ronald Robertson, Feb 16, 2006.
  1. Need an answer from the experts out there. A restorer I am NOT! Bought a new door data plate and rivets and I suspect one has to somehow do something with the rivets to make them expand as they just fall in and out of the hole in the door. Help!
    How do I expand these little suckers to make them stay in place?
    Ron
  2. Take a center punch that fits inside thehole and give it a rap, you can
    also use a phillips screwdriver
    >From: "Ronald Robertson" <ronald.robertson (AT) sympatico (DOT) ca>
    >To: "Shelby Mustang" <shelbymustang (AT) carmemories (DOT) com>
    >Subject: Hopefully changing the subject
    >Date: Sun, 29 Jan 2006 12:40:55 -0500
    >Ron
    _________________________________________________________________
    Don’t just search. Find. Check out the new MSN Search!
    http://search.msn.click-url.com/go/onm00200636ave/direct/01/
    Ron
    >>>Not to sound too glib, but rivits come in different sizes--are you
    sure you are using the right size?
    The variables are the diameter, and the grip length. Some rivits are
    very deep, enabling you to secure panels that are very thick, while
    others are much shorter and are appropriate for affixing a tag to
    sheetmetal.
  4. Mike:
    These are the correct rivets as supplied by Marti.
    Ron
    To: <ronald.robertson (AT) sympatico (DOT) ca>; <shelbymustang (AT) carmemories (DOT) com>
    Sent: Sunday, January 29, 2006 3:36 PM
    Subject: Re: Hopefully changing the subject
    > Ron
    > sheetmetal.
    > Mike
  5. I would not give them a 'rap'. these rivits are soft so you should only have
    to put the center punch or 'nail set' in ang give a bit of a push
    bob
