Info needed
Discussion in 'Shelby Mustang List' started by OLAF HERRICK, Jul 14, 2005.
  1. OLAF HERRICK
    OLAF HERRICK Guest
    Hello to all , since the SAAC 32 thing has sizzled a little I thought I would try and get some insight for my 66 K code fastback with 14" Torque Thrust wheels.
    I received the styled steel wheels with the black outer rim and trim rings with the car. The loose rims have dual red line tires which look to be about 4.5 "wide. I have a set of all chrome (wider) styled wheels from my 65 conv. Did 66 cars only come with the semi chrome wheels or were the all chrome wheels a possible option ?
    Is the jack the same appearance as the 67-68 Mustangs or are they different?
    The last question is just for my curiosity. I bought a set of 15" Torque Thrust wheels for my 65 conv and I cant get them to stop rubbing the fender wells (even replaced the frt. springs). I transferred the wheels that were on the K code fastback but I wonder . Can you run 15" wheels on the front of a 65-66 Mustang without it rubbing?? Thanks for your input. Olaf
