Hi Guys What leaf springs did they install in the 65/66 Shelbys?? Standard ones or one with higher spring rate?? 4 or 5 leafs?? Need info fast! Thank you very much Bye Jerry
As far as I know, leaf springs were not changed. What Ford installed on the Hi-Po Mustangs is what they used. There is a lot of speculation and mis-information on what was and wasn't installed at the San Jose plant and what was done at Shelby.
Hi Bill So you would say with standard 4 leafs i´m doing ok? I have an ofer for a pair of new standard ones so i´m going to buy them. Thank you! Bye Jerry
Jerry I have a book at home listing what was installed on a factory HiPo Mustang. I remember something about leaf springs on HiPo cars. I will look it up tonight. It was quite a few years ago when I rebuilt my springs, but as I remember it, they had more than 4 leafs. I will let you know later. Thanks Bill
Jerry Rear leaf springs were both 4 leaf. The standard spring was rated at 610 lbs. Stamped C4ZA-5560 H, J, R or V The springs installed on the HiPo cars was part of the "Special Handling Package" They were rated at 650 lbs. Stamped C4ZA-K. L, S or Y.
