Master Cylinder-and Valve Cover..
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by dodmort, Aug 11, 2009.
  1. dodmort
    dodmort Active Member
    sw us
    Have to admit.
    The 428 sitting there has always been a tight fit between the Cover and Cylinder. Know it was built that way.
    But
    after all these years the Master C. is out and I replaced it with a new one ( not nos---sorry, but keeping the original one stored safely).
    The replacement is a tighter fit than the original seems to me. Gained a few thousands by re-gasketing the old cover and putting it on the new cylinder...but still only have .035 to move with between the two..
    Would putting in new motor mounts help this...???
    still using the factory originals to this day..
    Any other ideas.?:confused:
  2. 2+2GT
    2+2GT Well-Known Member
    Coupla points. Torque moves the valve cover away from the MC, except in reverse. You don't race backward, much.
    Motor mounts might help, if the left one has sagged more than the right. Otherwise, it'll just go straight up. Of course, by loosening and tightening the motor mount bolts, shifting to the right while loose, you might get some more clearance.
  3. thefordshow
    thefordshow Well-Known Member
    Ontario Canada
    You can loosen the band clamp on the booster and rotate it away. I got about 1/4" between my cover and master this way. :thumbup:
  4. dodmort
    sw us
    Band clamp---
    duh---why didn't i uhhhh:wacko:
    will do it...
    way to suggest...
    Started it last nite
    put it back in the trailer..it stated slapping at idle when it got a little warmed up.
  5. shanefoster
    shanefoster Member
    Motor mounts ability help, if the left one has sagged added than the right. Otherwise, it'll just go straight up. Of course, by alleviation and abbreviating the motor arise bolts, alive to the appropriate while loose, you ability get some added clearance.
  6. 2+2GT
    More recently I had this problem, and the above tricks just didn't cut it. I removed the LH valve cover, padded the engine and master cylinder, and put a 5' long prybar in between. Coupla quick tweaks, and there was 1/4" clearance between the MC and valve cover. It all looked nice and straight when assembled, too, I have to figure the firewall etc., was a bit off to begin with.
