Mechanical Fuel Pump For 1965 Shelby
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by grm, Jan 12, 2008.
  1. grm
    grm Member
    Hi folks,...I'm still looking for a 3939s fuel pump for my 1965 Shelby. Haven't found anything yet. Any more ideas or people that I might ask?
    Greg
  2. shelby6t5
    shelby6t5 Well-Known Member
    If it is simply for the look, you could use a 3911s, the only difference is the second spring.
    There are other CABbureTER pumps that look very close, if not exact - the main issue being the arm.
  3. grm
    grm Member
    Hi Mike,...Thanks for the imput, but that's one of the problems...Can the "single spring" handle the high RPM's...in 6,000 range? I was under the impression that I might have a starvation problem and therefore engine miss...
    What do you think?
    Greg
  4. zrayr
    zrayr Well-Known Member
    TX
    I'm using a '65 style canister pump (non Hi-Po) on a basically stock 289 Hi-Po engine. I hit 6500 rpm regularly w/o any fuel starvation issues. ymmv.
    Z. Ray
  5. grm
    grm Member
    That sounds great! Is that the "3911 S" that Mike spoke about?
    And second question,...let me give you a little background. When I bought 5S456, it had an oil cooler already hooked up. Unfortunately it is located behind the vallance and therefore not really exposed to much air.
    To install the correct looking mechanical fuel pump, I would have to re-route the oil cooler lines or remove it all together. I'm thinking of maybe just removing it as I don't think it really does all that much and they really were not "stock" on street Shelbys. What do you think?
    If I don't remove, the lines are really in the way of where the new fuel pump would go. Can you believe it!!!???...Murphy's Law at every turn!
    Greg
  6. zrayr
    TX
    no, the pump I referred to is just a stock '65 289 pump. Not the "button top" type which has the outward appearance of the Hi-Po pump.
    about the oil cooler: the '65 GT-350 R models did have the oil cooler w/ the external lines, etc. and didn't appear to have any issues with the fuel pump interference with the cooler lines. Nice photo of that set-up in Tom Corcoran's book "Shelby Mustang".
    Z. Ray
  7. grm
    grm Member
    Thanks Z.
    Are you reffering to the one pictured in Tom Corcoran's Shelby Mustang book (I'm assuming that you have a copy since you referred to it in your last post)...pg.45? Is that the stock '65 type???
    Thanks for the help!
    Greg
  8. zrayr
    TX
    on page 28 was the photo of the '65 GT-350 R model with the oil cooler, etc.
    Z. Ray
  9. Bob Gaines
    This what the correct pump looks like. The correct 3939S sells in the 700.00 to 1200.00 range for NOS if you can find one . I have used cores but the problem is no one presently rebuilds this type. I hope this helps.
  10. grm
    grm Member
    Bob,...Thanks! Now I know what the "2-springs" looks like. I'll keep searching, as I'd like what the car came with...
    Greg
