New Gas - E85 and oxygenated gasoline
Discussion in 'Open Community Forum' started by Seaweed, Apr 17, 2006.
  1. Seaweed
    Seaweed Well-Known Member
    Will the new ethanol gas be good, bad or no difference for the cars of the 60's.---S
  2. roddster
    Re: New Gas
    Bad, very Bad. First off, this is where the "85" comes in. It's 85% ethanol, 15% Gasoline. It is however 105 octane, but requires changes in jetting. This will result in a 5 to 15% reduction in fuel mileage.
    Secondly, cars built to run on it have stainless steel metal parts, or otherwise coated to stop the corrosiveness of this fuel. And, only certain types of rubber fuel lines (and probably fuel pump membrane) will disintegrate in this fuel.
    There is an excellent response to a tech question about this in the June 2006 issue of Hot Rod Magazine.
  3. Seaweed
    Re: New Gas
    So, with that being said, what are you going to do , to get around this issue ??---Thanks,---S.
  4. roddster
    Re: New Gas
    I'm just gonna keep ponying up the money for the regular gas I use now.
  5. GT52
    GT52 Active Member
    Re: New Gas - E85
    Not sure, but I think two issues are being confused here.
    First, E85 is intended for use only in late model cars designed as "flex fuel" vehicles. You cannot run an old vehicle on E85.
    Second, alot of the country is just now getting its first taste of "oxygenated gasoline", required in many urban areas for many years now. Some of the recent price increase in gasoline can be attributed to the new "blend". Ethanol has replaced MTBE as the oxygenator of choice as MTBE has proven to be an environmental disaster. There isn't alot of ethanol in oxygenated gasoline, and its been used in alot of the country with only a moderate number of complaints involving rubber and seal deterioration. Unless you want to buy race gas in a can for your car you're going to have no choice soon but to run the oxygenated gasoline.
