Pie Charts I would appreciate some help deciphering a few parts. I bought a package deal of FE (CJ) parts from a guy and there are three parts that I'm having a hard time identifying. carb Holley C90F-9510 R list 4698 appears to be a 735 or 780, heat activated choke Carter X fuel pump (FE) , number on side 4583 date 15A9A (Jan 15 69) flywheel casting number C5AE-E , stamped number C7TE-A last question ; is a C3AE-C rod the same as a 428 CJ rod? I know it shows the application a 427 . Thanks Olaf
Olaf, I can only help you on two of your four items. From my 65-72 Master Parts Catalog (CD version) I found nothing on the fuel pump or connecting rod question. Carburetor is for 69-71 351W, 600cfm; it was also used as the replacement carb for '68 427, C6, T/E... I know the reaction that will likely gerate, but that's in the book... The Flywheel is also for 351W; '69, manual trans, 164 tooth ring, 12 3/8 bolt circle. Sorry I couldn't be of more assistance; perhaps you got the answers directly off the list. Tom Kubler 6S-wishing-6R Olaf Herrick <olaf (AT) gibsonet (DOT) com> wrote: BODY { MARGIN-TOP: 30px; FONT-SIZE: 10pt; MARGIN-LEFT: 25px; COLOR: #996600; FONT-FAMILY: 'Times New Roman', Helvetica } I would appreciate some help deciphering a few parts. I bought a package deal of FE (CJ) parts from a guy and there are three parts that I'm having a hard time identifying. carb Holley C90F-9510 R list 4698 appears to be a 735 or 780, heat activated choke Carter X fuel pump (FE) , number on side 4583 date 15A9A (Jan 15 69) flywheel casting number C5AE-E , stamped number C7TE-A last question ; is a C3AE-C rod the same as a 428 CJ rod? I know it shows the application a 427 . Thanks Olaf
