Power steering slave cylinder
Discussion in 'Shelby Mustang List' started by Tom Casperson, Mar 17, 2005.
  1. I have a little bit of play in my steering wheel on my
    69 GT-350. My mechanic says that it is my Power
    Steering Slave Cylinder that needs replaced. Does
    this sound correct? If so, does anyone have
    suggestions on where to purchase a rebuilt or new one?
    Anything else to replace at the same time?
    Tom
    __________________________________
    Do you Yahoo!?
    Make Yahoo! your home page
    http://www.yahoo.com/r/hs
  2. You could also try Pete Geisler at Orlando Mustang 1-407-688-1966
    Ron
    To: <shelbymustang@carmemories.com>
    Sent: Thursday, March 17, 2005 8:58 PM
    Subject: Power steering slave cylinder
    > Thanks,
    > Tom
    > Do you Yahoo!?
  3. ken mann
    ken mann Guest
    Tom; It has been my experience that you will end up rebuilding all of the
    steering components, and then still have play in your steering. The culprit
    usually turns out to be the joint inside the tilt column. Check the play in
    the column by having someone hold the pitman arm, while you try to turn the
    steering wheel. More than likely, there will be play. Very few cars have
    tight tilt columns. I can recommend a person in San Jose, CA who can
    rebuild it, although I have heard mixed reviews on the workmanship. Let's
    see if anyone else on the forum has had that same experience, and has a
    solution. Hope this "steers" you in the right direction!
    Ken Mann
    6S745
    6S490 (recent acquisition)
    Sent: Thursday, March 17, 2005 5:58 PM
    > Thanks,
    > Tom
    > Do you Yahoo!?
    > No virus found in this incoming message.
    > Checked by AVG Anti-Virus.
    > Version: 7.0.308 / Virus Database: 266.7.3 - Release Date: 3/15/2005
    No virus found in this outgoing message.
