Re: 1969 Rim blown horn
Discussion in 'Shelby Mustang List' started by ORLMUST@aol.com, Oct 22, 2005.
  1. In a message dated 10/22/2005 1:57:35 AM Eastern Standard Time,
    GT350HZ@aol.com writes:
    I am having a problem with my rim blown horn switch. The switch was pulled
    because it was not working, I reinstalled the original switch after receiving
    a defective switch. After reinstalling the original switch it worked fine.
    Now it seems to be misbehaving again. Is there something that may cause
    the contact of the switch to be intermittent?
    If the only solution is to replace the switch, I already have the part. I
    just figure it is worth seeing what experience others may have with the part
    and or the problem.
    Thanks Lee
    66 # 869
    69 # 2055
    10/22/2005
    Lee,
    The Horn Switch problem may be with a defective switch. We also see
    problems,
    when the track area is not clean and smooth.
    Call me for more instructions.
    Pete Geisler
    _www.OrlandoMustang.com_ (http://www.OrlandoMustang.com)
    407 688 1966
