Re: 1969 Shelby 15" wheel
Discussion in 'Shelby Mustang List' started by MikeLDrew@aol.com, Jul 30, 2005.
  1. In a message dated 7/29/05 21:45:40, bgaines@kc.rr.com writes:
    << The reason they went to a space saver is because once installed in the
    trunk and fully inflated a F60 15 will not be able to be taken out of a 69 trunk.
    It is stuck in there.So you have to go with a smaller diameter tire if you
    want it already inflated and readu for that flat. >>
    >>>To the best of my knowledge, the De Tomaso Pantera used the same
    space-saver spare tire as the period Mustangs. While Mustang collector guys seem
    willing to pay outrageous amounts of money for an original space-saver spare tire
    and wheel, Pantera guys routinely throw theirs in the trash! Once you put big
    racing brakes on a Pantera, the space-saver wheel can't physically be mounted
    on the car, so it becomes deadweight. And besides, if you should happen to
    have a flat and you pull your lovely Campagnolo magnesium wheel and tire off to
    install the spare, where would you put the flat? Surely you wouldn't leave it
    on the side of the road. So in this day of cell phones and Fix-A-Flat most
    Pantera guys forgo the spare.
    Mine is buried somewhere in my mother's basement, along with a second brand
    new, never-mounted original replacement tire for a space-saver wheel.....
    If you can't come up with any other solutions, I might be convinced to part
    with mine....
  2. Bob Gaines
    Bob Gaines Guest
    Mike you are basically right . The pantera space saver is the same as the
    1970 mustang spare but is different then the 69/70 Shelby. It is F78 15
    instead of 7.35 15 like in the 69/70 Shelby . The size when inflated is
    nearly the same and would work fine. Bob G.
    To: <bgaines@kc.rr.com>; <GT350HZ@aol.com>; <shelbymustang@carmemories.com>
    Cc: <ShelbyMustang@carmemories.com>
    Sent: Friday, July 29, 2005 11:56 PM
    Subject: Re: 1969 Shelby 15" wheel
    trunk.
    guys seem
    spare tire
    big
    mounted
    to
    off to
    leave it
    most
    brand
    part
    > with mine....
    > Mike
  3. Bob Gaines
    Bob Gaines Guest
    trunk.
    guys seem
    spare tire
    big
    mounted
    to
    off to
    leave it
    most
    brand
    part
    > with mine....
    > Mike
