Re: 427 dipstick question
Discussion in 'Shelby Mustang List' started by MikeLDrew@aol.com, Aug 23, 2005.
  1. In a message dated 8/23/05 7:25:51, dan_drury@midamcorp.com writes:
    << The next time you change the oil, put 4 quarts in and start the car and
    let
    it idle. Give it enough time to fill your filter and then stop the engine.
    Let it sit for a while then check your dipstick and mark it so you will know
    if your a complete quart low. Then I would add the fifth quart and run the
    engine and stop it and record where "full" is. (Based on a 5 qt.
    requirement)
    >>>Ah yes, but that's the rub--I don't know what the actual capacity of this
    oil pan is. Plus I have an oil cooler, remote oil filter, and with it quite a
    few feet of oil lines.
    >As far as the dipstick pushing up, I would check the PVC valve (already
    mentioned) and then maybe consider setting an O-ring into the bonnet of the
    dipstick. (I've never had to do that, but it might work for you.) >>
    >>>Well, realize that the dipstick is hitting something inside the engine
    (probably the windage tray). It used to go through it just fine, but over the y
    ears has become bent and is now apparently striking it and turning sideways
    instead of going through it into the oil. So the dipstick is being forced out
    mechanically--that is, when it's forced all the way home there is some 'spring'
    tension on it, and at the slightest bump it pops out again.
    I'm going to investigate getting a Lokar dipstick, primarily because it's a
    cable rather than a flat ribbon of steel and thus should be happy bending in
    all directions.
    Thanks!
