RE: 65-350 Stripe
Discussion in 'Shelby Mustang List' started by Bill Wells, Nov 17, 2005.
  1. Bill Wells
    Bill Wells Guest
    i just checked my branda catalogue from several years ago , and they claim
    the stripe dimensions in their catologue were direct from shelby american in
    1965, as designed by peter brock. . stripes were intended to be tapered,
    being wider in the middle than at the front or rear...if not tapered then
    the stripes appear to get smaller the further back on the car they go. when
    tapered they visually appear to be the same.
    for what its worth, acknowledging that many dealers probably did their own
    thing and variability existed, the branda reported measurements are :
    * a constant 2" between the stripes from front to rear.
    * the stripes are 9-1/4" at the bottom of the lower front valance which is
    the same dimension as the front of the hood over the grille
    * stripes measure 9-1/4" at the front of the hood and taper out to 10-1/2"
    at the cowl below the windshield as well as 10-1/2" at the roof at the
    windshield * the top stripes start at 10-1/2 " at the front and taper
    slightly to 10-3/8" at the back of the roof at the rear window moulding
    edge.
    * the stripes on the trunk are 10-1/8" wide at the rear window moulding
    tapering to 10" at the rear of the trunk and 10" down behind the rear bumper
    to the bottom of the rear valance which is also 10"
    now, when you are picking fly droppings out of pepper, like these
    measurements that vary an 1/8" or so, one can imagine the variablity of the
    dealers / painters who masked them out for painting. without a template it
    would be hard to imagine out of 10 cars how many were the same exact
    measurements when done.
    I dont make this up, i just report the news, as branda printed. LOL...bill ,
    motown , flyswatter with measurement calipers
    -----Original Message-----
    From: Bill Wells [mailto:wwells249101MI@comcast.net]
    Sent: Thursday, November 17, 2005 7:54 AM
    To: speegle@pipeline.com; jonlee@wt.net; Shelby List
    Subject: RE: 65-350 Stripe
    i dont have a tony branda catalogue handy, will look later, but i know my
    most current is a couple of years out of date. however, in the last couple i
    saw they had paint codes for some of the stripe colors ( hertz gold anyway)
    and showed the correct dimensions for the stripes as they moved from front
    to rear. and they DID DIFFER dimensionally as they extended from front to
    back. the stripes were NOT uniform in width , instead varied for an optical
    affect of visual uniformity . bill, motown
    From: speegle@pipeline.com [mailto:speegle@pipeline.com]
    Sent: Thursday, November 17, 2005 12:55 AM
    To: jonlee@wt.net; Shelby List
    Subject: Re: 65-350 Stripe
    Not sure how much differenence ther is between the hood and cowl stripes but
    try this.
    The original instructions Shelby used and supplied to dealers called for
    trappered stripes (thinner at the front and rear of the car) to reduce the
    coke bottle effect that consistant thickness stripes would visually cause.
    Since prep was just enough we would expect to see paint overspray into the
    cowl sections. If they were dealer and even Shelby done, there would be
    overspray in a number of other areas. Of course these cars are often over
    restored. ... remember a R model that had stripes applied inside the cowl
    then they reinstalled the cowl.
    Hope this helps
    Jeff S
    Sent: Nov 16, 2005 9:40 PM
    To: Shelby List <shelbymustang@carmemories.com>
    Subject: 65-350 Stripe
    Hey Alpha Omega Shelby guys:
    I have a question. I just looked over my 65-350 car to help a friend out on
    his 65 350 car purchase and I discovered something I think is unusual on my
    car.
    The Le Mans stripes dont exactly line up and the car was ordered with
    factory Le Mans stripes. It seems that the stripes on the fiberglass hood
    are narrower then the stripes on the cowl vent area
    and on the top.
    Basically, the top and cowl stripes are wider than the stipes on the hood.
    Is this correct or did someone mess around with it. There is about a 2 inch
    gap between the stripes thats even through out
    the car but the width of the skunk stripes are not the same.
    Whats also interesting is that the cowl vent didn't get covered up when they
    painted the stripes. I can see blue paint inside the cowl vent area.
    Thanks for any info.
    jon
  2. The stripe dimensions are also in the back of the latest SAAC Registry.
    Dave
    >edge.
    >try this.
    >Hope this helps
    >Jeff S
    >From: jonlee@wt.net
    >car.
    >and on the top.
    >jon
