Re: 68 GT350 5-Sp Swap Awsome!
Discussion in 'Shelby Mustang List' started by MikeLDrew@aol.com, Jul 26, 2005.
  1. In a message dated 7/26/05 12:15:19, mrgt350@yahoo.com writes:
    << I had one in a high strung 65. Did not like it
    because the rpms drop was to big in 5th. I think it
    was .79 OD. >>
    >>>The 'standard' overdrive ratio is very, very tall--something like .58???
    An optional .80 ratio is available, which would be much more reasonable--the
    gap from 4th to 5th would be similar to the gap from 3rd to 4th.
  2. Colin Comer
    Colin Comer Guest
    I have a T5Z in both my 65 #144 and my 66 Paxton car #1636. The T5Z is an
    upgraded T5 , carbon fiber synchros, etc... and the torque rating is better.
    They shift really nice once broken in properly. I got mine from Modern
    Driveline in California, I think they were around $1300 for the trans only.
    I think the standard 5th gear is .64. I put the optional .83 in both. With a
    3.50 rear and stock size tires that are roughly 26" overall, it is a good
    combo. I think the math worked out to a final drive of 3.07:1 in fifth gear.
    #144 ran the Copperstate 1000 this year, and Alain DeCadenet (Victory by
    Design) and I co-drove one day, about 300 miles, with a stretch of road
    where we did not go below 130 MPH for a full tank of fuel! The car was very
    relaxed at that speed in 5th, I recall it was around 4-4500 rpm, or whatever
    is straight up on a 65 tach. And even though the speedo gear is changed to
    supposedly be accurate, it was still way off ! We replied on GPS to check
    speed and mileage. Best speed we saw was 146 MPH, and I started to be very
    concerned about the speed rating of my tires being exceeded, and backed off!
    The one problem I have had with all of the cars that I have converted is the
    clutch pedal sticking to the floor on really high rpm shifts. I think it has
    to do with using a diaphram clutch rather than a Long style. Have added
    return springs, pedal stops, and properly adjusted - think it is just a
    result of the old bellcrank style linkage on a modern Centerforce clutch. I
    know a hydraulic clutch or cable system would fix it, but can't bring myself
    to drill holes or make the car look non-original under the hood!
    Just my $.02.....
    Colin
    To: <mrgt350@yahoo.com>; <SSIMM@triad.rr.com>; <indy_carl50@yahoo.com>;
    <shelbymustang@carmemories.com>
    Sent: Tuesday, July 26, 2005 2:18 PM
    Subject: Re: 68 GT350 5-Sp Swap Awsome!
    > was .79 OD. >>
    > reasonable--the
    > Mike
