Re: 69/70 Shelby rear tail panel.more
Discussion in 'Shelby Mustang List' started by Robert Gaines, Mar 10, 2005.
  1. In the case of the front valence I should have been more clear because
    the black out effect blends the area around the park bezel that is made
    up when the front valance and front fender connect together . The black
    out areas are a pet peave of mine because they are regularly left off.
    Bob G.
    On Wednesday, March 9, 2005, at 10:53 PM, Robert Gaines wrote:
    > David ,you asked. What color is the 69/70 Shelby tail panel? The
    > front side of the tail panel is painted semigloss black before being
    > installed on the car. the trunk side is left unpainted. The end caps
    > were painted off the car too.What you are refering to is something a
    > lot of restorers forget to do,which is a black out line on the end
    > caps were it overlaps the tail panel . Another place this blending
    > effect is done is on the lower front valance were the park lights are
    > installed . The black out creates the illusion that the two
    > seperate components are connected. In the case of the end caps it is
    > different between fastback and convertables because the endcaps are
    > shaped different. In the case of the front valence it is between the
    > semi gloss parklight bezal and the surrounding fiberglass area(which
    > is blacked out) in which the bezal is installed on the valence. I
    > hope this helps. Bob G.
    > On Wednesday, March 9, 2005, at 05:17 PM, DAVID DYER wrote:
    >> Anyone know the correct colour set up for the rear tail panel.Almost
    >> half the cars viewed on various galleries shows the rear panel to have
    >> been painted (before fitting of tail light assy) up to the fender
    >> extension edge with semi gloss black ! All the other cars looked at
    >> had body colour up to the edge of the tail lamp fibreglass,leaving it
    >> the only black in the area.
    >> Any Ideas at all ?
    >> Regards,Dave
    >> Glasgow,Scotland.
    >> ' 69 gt350, 1619
