Re: Back up lights ?1969
Discussion in 'Shelby Mustang List' started by Robert Gaines, Feb 16, 2006.
  1. The assembly line BU lights and some early service replacements had the
    engineering number silk screened on the rubber sheath covering the
    wires . Lense size was a early late thing. I believe tall was early
    short was late. Hope this helps. Bob G.
    On Friday, January 6, 2006, at 11:42 PM, fordmond (AT) swbell (DOT) net wrote:
    > Hello All,
    > Are there any differences From the BU lights installed at the Factory
    > in '69,compared to the Service replacements C9ZZ.The Ford over the
    > Counter items?
    > I know the 67 Housing was used, and there were different styles of
    > lenses used.What about the wiring?Did the service parts have the white
    > letters & #'s on them?Which lense is correct for the 69.
    > I've seen short and tall.
    > Thanks JW
  2. Guest
    Guest Guest
    Thanks Bob,
    So over the counter parts later on would Not have the white #'s....correct?
    I just got a set in"NOS" they said.The #'s on 1 of the housings is C7 15A
    509 A with FoMoCo Logo and No White letters on the wires.
    The red Pigtail is a litte bit Different too.
    I have a bunch of used factory style BU lights assy's on hand and the red
    plug part is a bit bigger with T M C letters on them.Any ideas on that?
    JW
    From: "Robert Gaines" <bgaines (AT) kc (DOT) rr.com>
    To: <fordmond (AT) swbell (DOT) net>
    Cc: <shelbymustang (AT) carmemories (DOT) com>
    Sent: Friday, January 06, 2006 11:59 PM
    Subject: Re: Back up lights ?1969
    > engineering number silk screened on the rubber sheath covering the wires .
    > Lense size was a early late thing. I believe tall was early short was
    >> Hello All,
    >> Are there any differences From the BU lights installed at the Factory in
    >> '69,compared to the Service replacements C9ZZ.The Ford over the Counter
    >> items?
    >> I know the 67 Housing was used, and there were different styles of lenses
    >> used.What about the wiring?Did the service parts have the white letters &
    >> Thanks JW
