RE: Batteries
Discussion in 'Shelby Mustang List' started by Bill Wells, Oct 7, 2005.
  1. Bill Wells
    Bill Wells Guest
    i posted earlier that i bought an Antique Auto Battery for my 57 TBird ,
    see : http://www.antiqueautobattery.com/
    they show both acid filled and sealed maintenance free batteries. i got the
    latter, which appears to have an Optima battery inside a concours correct
    original style casing. You need to call them for their offerings as at the
    time i bought battery it was not on their website but was in fact available.
    Since my 65 Mustang Superformance Cobra replica batteries were relatively
    new I did not check their Ford offerings for batteries other than what I was
    looking for. I got the battery in April and it has served me well so far.
    Pricey but for what I wanted , it was worth it.
    As a side, I had used the Battery Tender once on two of my cars and had to
    add water to the batteries every month during winter storage.I forgot one
    month and noticed my tender warning light was no longer going from red
    (charging ) to green (charged) but rather stayed red. Turns out ALL my water
    had disappeared and both batteries were toast. So, i had two tenders that I
    tossed and now just disconnect the batteries for long storage periods, and
    charge them overnight after storage before their first usage ( antique auto
    battery excluded as this will be its first winter ...even then it will not
    be 'tenderized' so to speak, just disconnected ). bill, Motown
    -----Original Message-----
    From: Ronald Robertson [mailto:ronald.robertson@sympatico.ca]
    Sent: Friday, October 07, 2005 12:16 PM
    To: RSANTER@aol.com; shelbymustang@carmemories.com
    Subject: Re: Batteries
    Bob:
    In an earlier post, a lister bought a battery for his Thunderbird from
    Antique Auto Battery. He either stated, or hinted strongly, that AAB had
    taken an empty shell and put an Optima battery inside.
    I would imagine cutting one open, removing all the acid and innards and
    replacing it with an Optima or similar would be easier the second or third
    time one had done it.
    Ron
    To: ronald.robertson@sympatico.ca ; shelbymustang@carmemories.com
    Sent: Friday, October 07, 2005 9:29 AM
    if you like the look of the battery you have, would it be possable to
    empty or gut out the battery and then use it as a shell to hold one of those
    compact,sealed, high powered racing batteries?
    just a thought
    in fact I always wondered why nobody has made just a repo battery shell
    to do that.
    one other thing I have always wondered. if you were to drain the battery
    and refill it with fresh electrolite, would the battery work good again? and
    for how long?
    bob
