Re: clutch questions
Discussion in 'Shelby Mustang List' started by MikeLDrew@aol.com, Feb 16, 2006.
  1. In a message dated 12/27/05 17:50:11, olaf (AT) gibsonet (DOT) com writes:
    << Second for you race veterans do these heavy duty clutches tend to bend
    linkages (I drive conservative mostly). >>
    >>>I had a Hayes three-finger clutch on my 427 Cobra. It was absurdly stiff.
    My car uses a hydraulic clutch actuation scheme (master cylinder and
    internal hydraulic throwout bearing), and the heavy clutch caused noticeable wear to
    the pivot points on the clutch pedals, and finally caused the throwout bearing
    to blow apart.
    I removed it and sold it for a song, then installed a proper Centerforce
    diaphram clutch. What a difference! It is about 1/4 the effort yet still holds
    up just fine to over 500 hp.
    I suspect once you ditch your Hayes clutch, your linkage will survive just
    fine.
