Re: clutch questions
Discussion in 'Shelby Mustang List' started by DMGT350@aol.com, Feb 16, 2006.
  1. I agree with Mike, go with a Centerforce Dual Friction.
    Dave
    In a message dated 12/27/2005 5:58:26 PM Pacific Standard Time,
    MikeLDrew (AT) aol (DOT) com writes:
    > In a message dated 12/27/05 17:50:11, olaf (AT) gibsonet (DOT) com writes:
    > << Second for you race veterans do these heavy duty clutches tend to bend
    > linkages (I drive conservative mostly). >>
    > >>>I had a Hayes three-finger clutch on my 427 Cobra. It was absurdly
    > stiff.
    > My car uses a hydraulic clutch actuation scheme (master cylinder and
    > internal hydraulic throwout bearing), and the heavy clutch caused noticeable
    > wear to
    > the pivot points on the clutch pedals, and finally caused the throwout
    > bearing
    > to blow apart.
    > I removed it and sold it for a song, then installed a proper Centerforce
    > diaphram clutch. What a difference! It is about 1/4 the effort yet still
    > holds
    > up just fine to over 500 hp.
    > I suspect once you ditch your Hayes clutch, your linkage will survive just
    > fine.
    > Mike
