Re: Fwd: Re: 1965 Shelby Radios
Discussion in 'Shelby Mustang List' started by jonlee@wt.net, Jul 22, 2005.
  1. Lee
    I just looked at the car again and you are right. The speaker grille is still there right next to the pod, but I forgot that the metal grille was the speaker grill too along with the defrosters. Im
    so used to the 67 Mustang setup where the speaker holes are in the dash pad. I think I saw the Fomoco Speaker.
    This car is so different.
    Thanks
    jon
    Quoting lmathias@bellsouth.net:
    - The speaker should be in the stock location. The hole you see hacked in the dash is where Shelby cut it to install the oil pressure line. The tach pod actually only covers part of the speaker
    - hole. The car should have both the defroster ducts under the grill where the speaker goes. The pod goes over the grill after the speaker and ducts are installed. LEE MATHIAS
    - > From: jonlee@wt.net
    - > Date: 2005/07/22 Fri AM 10:15:57 EDT
    - > To: Shelby List <shelbymustang@carmemories.com>
    - > Subject: Fwd: Re: 1965 Shelby Radios
    - > Sorry to bug ya'll about my 65 Shelby car but I have another question.
    - > If the car did not originally have a radio and dealer installed one, where did the speaker/speakers go?
    - > WHen I opened the guage pod, I saw that they literally "hacked" the center dash board pad and the whole pod covers the speaker holes in the middle.
    - > Did they put the speakers back in the factory location or were was it re-located somewhere else?
    - > jon
    - > ----- Forwarded message from STAN SIMM <SSIMM@triad.rr.com> -----
    - > Date: Fri, 22 Jul 2005 08:16:53 -0400
    - > From: STAN SIMM <SSIMM@triad.rr.com>
    - > Reply-To: STAN SIMM <SSIMM@triad.rr.com>
    - > Subject: Re: 1965 Shelby Radios
    - > To: jonlee@wt.net, Shelby List <shelbymustang@carmemories.com>
    - > Jon-Yep, you could get a radio with your '65 GT-350. Most were probably
    - > dealer installed, tho. There is a light in the radio but I believe you have
    - > to take the radio out and take the faceplate off to replace it. The FoMoCo
    - > factory shop manual lists the bulb as a #1891. Maybe others on the list have
    - > actually changed one out and can describe how it's done.
    - > Regards, Stan
    - > ----- Original Message -----
    - > From: <jonlee@wt.net>
    - > To: "Shelby List" <shelbymustang@carmemories.com>
    - > Sent: Thursday, July 21, 2005 11:13 PM
    - > Subject: 1965 Shelby Radios
    - > > Everyone:
    - > > Does anyone know about the 65-350 radios? I can't seem to figure out why
    - > the radio light does not come on when I turn the dash lights on or does it
    - > have lights in there. I spent 30 minutes replacing
    - > > all the old factory dead bulbs in the dash since no one bothered to
    - > replace them and the radio is the only one left. Did these 65 -350 cars
    - > even came with radios?
    - > > Any help is greatful as Im learning about these 65 Shelbys. Thanks
    - > > jon
    - > ----- End forwarded message -----
