Re: Info needed
Discussion in 'Shelby Mustang List' started by g adams, Jul 14, 2005.
  1. g adams
    g adams Guest
    Check the caster. If the caster is off it will
    position the wheel further forward in the fender
    opening.
    Greg
    www.uniquemotorcars.net
    --- OLAF HERRICK <olaf@gibsonet.com> wrote:
    > Hello to all , since the SAAC 32 thing has sizzled a
    > little I thought I would try and get some insight
    > for my 66 K code fastback with 14" Torque Thrust
    > wheels.
    > I received the styled steel wheels with the black
    > outer rim and trim rings with the car. The loose
    > rims have dual red line tires which look to be about
    > 4.5 "wide. I have a set of all chrome (wider) styled
    > wheels from my 65 conv. Did 66 cars only come with
    > the semi chrome wheels or were the all chrome wheels
    > a possible option ?
    > Is the jack the same appearance as the 67-68
    > Mustangs or are they different?
    > The last question is just for my curiosity. I bought
    > a set of 15" Torque Thrust wheels for my 65 conv and
    > I cant get them to stop rubbing the fender wells
    > (even replaced the frt. springs). I transferred the
    > wheels that were on the K code fastback but I wonder
    > . Can you run 15" wheels on the front of a 65-66
    > Mustang without it rubbing?? Thanks for your
    > input. Olaf
    __________________________________________________
    Do You Yahoo!?
    Tired of spam? Yahoo! Mail has the best spam protection around
    http://mail.yahoo.com
