Re: Low gloss black paint for engine compartment
Discussion in 'Shelby Mustang List' started by GT350HZ@aol.com, Mar 1, 2005.
  1. I have sprayed and sanded several areas of the engine compartment using a
    spray can for the last couple of years. The paint seems to fade on the shock
    towers, so I have redone them by spray can a couple of times. Last time they
    did not come out as smooth as I would like. I am not ready to pull the engine
    and redo the whole engine compartment as of yet. I was going to strip the
    shock towers and redo them, so I wanted to get some ideas. I probably will
    break down and have my painter do the work at the end of summer for the last
    couple of major local shows... unless I do a fantastic job with a spray can
    (like I did the year before last) :). Is it your experience that the regular
    Krylon goes on much better than the high heat?
    Thanks for your suggestions
    Lee 66 # 869
