Re: Low gloss black paint for engine compartment
Discussion in 'Shelby Mustang List' started by DMGT350@aol.com, Mar 2, 2005.
  1. Another thing you might consider is powder coating the shock tower tops.
    While obviously not correct for a concours car the results and durability can be
    great for a restored street car. I had a local shop use a semi-flat black
    powder coat on my export brace, sway bar, under ride traction bars, and rear
    brake backing plates. I've been very satisfied with the results, I wish I had
    done the shock tower tops back then since they do tend to fade and collect little
    chips. The export brace color was a perfect match for the engine
    compartment. After nearly 10 years there's been no fading or chips in the powder coated
    pieces.
    Dave
    In a message dated 3/1/2005 8:52:47 PM Pacific Standard Time,
    bgaines@kc.rr.com writes:
    > Keep in mind that some of the high heat paints and some of the engine
    > enamels when sprayed on will react (wrinkle up) if you have to go back
    > in and spray over to touch up such as to fix a drip etc, unless it is
    > fully cured which sometimes takes many months. Be sure to read the
    > label , the ones that will wrinkle will usually mention that it has to
    > cure. Krylon if you have to use it ,will touch up easily and blends well
    > with the surrounding area. I think Krylon semi gloss (1312)is a little
    > too flat for a engine compartment. Good luck with the project. Bob G
    > On Tuesday, March 1, 2005, at 09:36 PM, GT350HZ@aol.com wrote:
    > > I have sprayed and sanded several areas of the engine compartment using
    > > a spray can for the last couple of years. The paint seems to fade on
    > > the shock towers, so I have redone them by spray can a couple of
    > > times. Last time they did not come out as smooth as I would like. I am
    > > not ready to pull the engine and redo the whole engine compartment as
    > > of yet. I was going to strip the shock towers and redo them, so I
    > > wanted to get some ideas. I probably will break down and have my
    > > painter do the work at the end of summer for the last couple of major
    > > local shows... unless I do a fantastic job with a spray can (like I did
    > > the year before last) :). Is it your experience that the regular
    > > Krylon goes on much better than the high heat?
    > > Thanks for your suggestions
    > > Lee 66 # 869
