Re: oil survey more info
Discussion in 'Shelby Mustang List' started by RSANTER@aol.com, Jun 7, 2005.
  1. as long as you do not heat the oil to the point of damaging it
    (burning/breaking down) then it is my understanding that the oil never wears out. I have
    heard that the additives will wear out but the base oil itself will not.
    I would personally feel uncomfortable with doing that in my car as changing
    the oil will remove any contaminants in the oil. the debree should get trapped
    by the filter.
    a friend of mine in high school was given a dodge dart as a first car from
    his father. his father was the original owner and never changed the oil or
    filter. eventually when the engine went down a quart, he would add a quart. he
    would say, after adding a few quarts you have esentally changed the oil. when
    his father gave him the car he told him to not change the oil but to continue
    with the set course. the car never smoked and only needed oil added every few
    months. all this and the car had over 100k on it.
    well shortly after getting the car, Robert (my friend) changed the oil.
    immediatly the car started to smoke and burn oil. no amount of STP or other
    additived would do a thing to change it. needless to say his father gave him a big
    rash of shit over that. they ended up putting a running used engine in the
    car.
    bob
