Re: Re: 427 dipstick question
Discussion in 'Shelby Mustang List' started by Guest, Aug 22, 2005.
  1. Guest
    Guest Guest
    The spark plug boot works great. In addition to it we used a spring on the dipstick to hold it down. Drill a small hole in the dipstick handle and hook the spring under the bracket that bolts the dipstick tube to the engine. A lightweight carburetor return spring works good. Crankcase pressure pushes it up. Is your PCV operating properly?
    > From: "STAN SIMM" <SSIMM@triad.rr.com>
    > Date: 2005/08/22 Mon PM 08:34:45 EDT
    > To: <MikeLDrew@aol.com>, <shelbymustang@carmemories.com>
    > Subject: Re: 427 dipstick question
    > Mike-Can't tell you about the dipstick but I can give you a simple tip for
    > the future. To avoid regurgitating oil up and out the dipstick tube, help
    > hold the dipstick in place by slipping an inverted spark plug boot over the
    > dipstick tube. Then firmly seat the dipstick down into the inverted boot
    > and it'll help hold it in place.
    > Regards, Stan
    > ----- Original Message -----
    > From: <MikeLDrew@aol.com>
    > To: <shelbymustang@carmemories.com>
    > Sent: Monday, August 22, 2005 8:12 PM
    > Subject: 427 dipstick question
    > > Hi guys,
    > > I had a blast driving my Contemporary Cobra to Monterey this year, and
    > > celebrated making it home unscathed by just nipping 145 mph on the 505
    > before
    > > turning off at my exit. Whee!!!
    > > When I parked in the driveway for just a moment while the garage door
    > opened
    > > (at midnight), several drops of oil, well, dropped.
    > > The cause is my dipstick. To put it plainly, it is totally screwed. It
    > > bends in two planes; not only does it curve as a flat piece of metal
    > normally
    > > would, but it also curves sideways, which is almost impossible to
    > conceive.
    > > Here's a photo to show what it looks like; this is shot looking straight
    > down
    > > at the flat surface of the dipstick:
    > > http://members.aol.com/mikeldrew/dipstick.jpg
    > > In fact, the dipstick doesn't even touch the oil; it appears to curve
    > upwards
    > > and to the left as soon as it enters the motor. So at oil change time I
    > just
    > > have to guess how much oil to put into the motor, never a good thing. It
    > > also 'springs' back; when I seat it home, it meets resistance and as soon
    > as the
    > > engine starts, it pops back out about an inch.
    > > Well, apparently the 5500 rpm I was spinning on the freeway pumped a fair
    > bit
    > > of oil out the dipstick tube and all over the engine bay.
    > > So, the question is this--where the hell do you buy a new dipstick? The
    > one
    > > I have is marked C7AE 6750-A, and has been shortened and marked by
    > somebody in
    > > the past with a new 'full' mark considerably higher than the original one.
    > > So, what do I do now? I now haven't the slightest idea how much oil is in
    > > the engine, and no good way to measure it. My oil pressure is still fine,
    > but I
    > > don't want to burn up a 427 for such a stupid reason.
    > > Any advice is appreciated!
    > > Mike
  2. STAN SIMM
    STAN SIMM Guest
    While we're on the subject of dipsticks, that reminds me of a nagging
    question about Cobra T-Pans. Knowing that I may well be exposing my own
    stupidity here: Using the correct length original dipstick, I can't get more
    than 5-1/2-6 qts. into a Cobra T-Pan w/o it reading too full, even after
    starting it and letting the oil filter fill up. I've tried this on numerous
    pans w/the same results. These things were advertised to be 7 qt. pans,
    right?
    So, what's the straight scoop?
    Regards, Stan
    To: "STAN SIMM" <SSIMM@triad.rr.com>; <MikeLDrew@aol.com>;
    Sent: Monday, August 22, 2005 9:35 PM
    Subject: Re: Re: 427 dipstick question
    for
    help
    the
    boot
    > > Regards, Stan
    > > > Hi guys,
    > > before
    > > opened
    It
    > > normally
    > > conceive.
    straight
    > > down
    > > upwards
    I
    > > just
    It
    soon
    > > as the
    fair
    > > bit
    The
    > > one
    > > somebody in
    one.
    is in
    fine,
    > > but I
    > > > Mike
