Re: Re: Possible 67 wheels
Discussion in 'Shelby Mustang List' started by Guest, Aug 2, 2005.
  1. Guest
    Guest Guest
    Don't use adapters. They are aluminmu and weaken the attachment of the wheel to the hub. High speed cornering (nobody I know does this) or a good bump (pot hole) could cause the adapter to break and the wheel will come off. If you participate in open track events, definitely bolt the wheel directly to the hubs front and rear. While I am on the subject, never run less than the correct number of lug nuts on a wheel. If you break a stud, replace it.
    > From: ecj <ecj@peoplepc.com>
    > Date: 2005/08/02 Tue PM 04:01:05 EDT
    > To: CARMEMORIES <shelbymustang@carmemories.com>
    > Subject: Re: Possible 67 wheels
  2. I agree with Lee. I use wheel adapters for my front wheels (Weld rims) on my 67 drag mobile BUT I dont do high speed cornering or open track stuff. Ive hit several pot holes with it but then again I
    always check the studs for breakage.
    jon
    Quoting lmathias@bellsouth.net:
    - Don't use adapters. They are aluminmu and weaken the attachment of the wheel to the hub. High speed cornering (nobody I know does this) or a good bump (pot hole) could cause the adapter to break
    - and the wheel will come off. If you participate in open track events, definitely bolt the wheel directly to the hubs front and rear. While I am on the subject, never run less than the correct
    - number of lug nuts on a wheel. If you break a stud, replace it.
    - > From: ecj <ecj@peoplepc.com>
    - > Date: 2005/08/02 Tue PM 04:01:05 EDT
    - > To: CARMEMORIES <shelbymustang@carmemories.com>
    - > Subject: Re: Possible 67 wheels
    While generally this is true, and in the distant past it was VERY true,
    but things have gotten batter over the years. I know of several people who
    have used these adapters/spacers in track applications with no problems. I
    have a set for a Mustang. While I haven't used them, I can tell you they
    are of the highest quality and if I had the need to use them, I would have
    no reservations in all but the most extreme track applications.
    http://www.hrsprings.com/site/products/trak.html
    Calvin
    http://motors.search.ebay.com/_W0QQsassZcalvin767
