Re: Re: tire choice
Discussion in 'Shelby Mustang List' started by Guest, Apr 24, 2005.
  1. Guest
    Guest Guest
    > Good comments. I am not sure about the 66 ten spokes, but the 67 - 68 15" ten spokes have a positive offset. The Magnums have a 0 offset which can mean 1/4" to 1/2" less backspace than the ten spokes. How about someone out there with the 14" Magnums?
    > From: DMGT350@aol.com
    > Date: 2005/04/23 Sat PM 10:00:35 EDT
    > To: lmathias@bellsouth.net, ianroberts037@sbcglobal.net,
    > shelbymustang@carmemories.com
    > Subject: Re: tire choice
    > I'm running BFG 235/60R14 TA's on my 66 with the original 10-spokes and there
    > are no clearance problems with the upper ball joints. I don't know how the
    > 10-spoke offset compares to the magnum though. Plus my fender lips were rolled
    > during it's racing days so I don't know if that would be an issue with
    > unmolested fenders.
    > Dave
    > 6S1757
    > In a message dated 4/23/2005 6:47:27 PM Pacific Daylight Time,
    > lmathias@bellsouth.net writes:
    > > > You are probably at optimal size for a 14" wheel. If you go much wider
    > > the cross section increases and will hit the upper control arm on the lip
    > > around the ball joint. This will eventually wear through the sidewall. The 15"
    > > wheels carry the tire above the ball joint.
    > > > From: "ian roberts" <ianroberts037@sbcglobal.net>
    > > > Date: 2005/04/23 Sat PM 04:08:40 EDT
    > > > To: "Shelby LIST" <shelbymustang@carmemories.com>
    > > > Subject: tire choice
    > > > Dear all
    > > > I'm about to replace the set of tires I have on my '66 GT 350H. I was
    > > really seeking some suggestions from other owners about what to fit my car out
    > > with. The wheels are the standard magum 500's, I'm currently running Goodyear
    > > Eagle GT+4 at size 215/60R14.
    > > > Any advice?
    > > > Thank you
    > > > Ian
    > > > '66 # 845
  2. ken mann
    ken mann Guest
    I have a set of N.O.S. 14" painted Magnums for my 66 Shelby, and the
    backspacing is 3 7/8" and I am running a 205/70/14 tire, which is the
    closest size to the original Blue Streaks. No clearance issues.
    Hope this helps.
    Ken Mann
    To: <DMGT350@aol.com>; <ianroberts037@sbcglobal.net>;
    Sent: Sunday, April 24, 2005 6:52 PM
    Subject: Re: Re: tire choice
    there
    the
    rolled
    > > unmolested fenders.
    > > Dave
    > > 6S1757
    wider
    lip
    sidewall. The 15"
    > > > > Dear all
    was
    car out
    Goodyear
    > > > > Any advice?
    > > > > Thank you
    > > > > Ian
    > > > > '66 # 845
    > No virus found in this incoming message.
    > Checked by AVG Anti-Virus.
    > Version: 7.0.308 / Virus Database: 266.10.2 - Release Date: 4/21/2005
    No virus found in this outgoing message.
  3. STAN SIMM
    STAN SIMM Guest
    I concur w/Ken. 205/70x14 is the closest equiv. to the original tire
    profile. I'm running that size on 6S1467 w/orig. 10-spokes.
    Regards, Stan
    To: <lmathias@bellsouth.net>; <DMGT350@aol.com>;
    <ianroberts037@sbcglobal.net>; <shelbymustang@carmemories.com>
    Sent: Tuesday, April 26, 2005 12:30 AM
    > Hope this helps.
    > Ken Mann
    > From: <lmathias@bellsouth.net>
    and
    > there
    how
    > the
    were
    > rolled
    > > > unmolested fenders.
    > > > Dave
    > > > 6S1757
    > wider
    the
    > lip
    > sidewall. The 15"
    > > > > > Dear all
    > was
    my
    > car out
    running
    > Goodyear
    > > > > > Any advice?
    > > > > > Thank you
    > > > > > Ian
    > > > > > '66 # 845
