Re: Shelby traction bars Needed?..
Discussion in 'Shelby Mustang List' started by Guest, Aug 1, 2005.
  1. Guest
    Guest Guest
    66 Shelby underride bars weld right on, would be sorta correct as they came from an earlier one. Overrides are a pain in the butt to put in, plus leaks and forget it if you have a convertible. You can always bolt on a set of Mr Gasket woopie bars or slapper bars. How red is your neck, do you chew?
    Want a real challenge? Change it to staggered shocks. Find the upper mounting frame member and graft it into yours, the shock mounts for the axle plates are easy to find. 2 cents worth, FREE.
    > From: "Cevon Mclean" <cmclean@rbhnrc.usda.gov>
    > Date: 2005/08/01 Mon PM 04:12:23 EDT
    > To: shelbymustang@carmemories.com
    > Subject: Shelby traction bars Needed?..
    > Hey Guys,
    > I need traction bars for my gt350 1968...
    > What have you used with good success...
    > I get a load of wheel hop when doing burnouts...
    > I want to add something that looks stock...uppers?/lowers?...
    > When I added my 5sp, the slight increased angle must have
    > effected the geromerty... no virbration otherwise
    > THANKS!@
    > Cevon...
    > Yea i know, i shouldent be doing burnouts.....
    > I just need to smoke (Puff) some rubber once in a while...hehehe..
    > I hate getting the shakes if i dont...
