Re: [Shelbymustang] Jacking up and jack stands? for Jody
Discussion in 'Shelby Mustang List' started by RSANTER@aol.com, Aug 10, 2006.
  1. TheCarSource.com Shelby Mustang List
    There is much debate over how to store a car for a period of time. Most
    argue if the car should be on the suspension or not. I have heard bad things
    about having the car off the suspension but have yet to figure out why it is so
    bad (other than for the shocks). one option is to just have it on a second set
    of cheap tires/rims.
    bob
    _______________________________________________
    ShelbyMustang mailing list
    Send email to ShelbyMustang (AT) thecarsource (DOT) com
    Membership Administration http://thecarsource.com/mailman/listinfo/shelbymustang_thecarsource.com
    Group Web Page http://www.thecarsource.com/shelbymustang
  2. TheCarSource.com Shelby Mustang List
    Bob,
    Having the car raised in a fashion that the suspension is hanging for an
    extended period of time can cause the suspension parts to bind and
    weaken almost like your own body joints from over extending when hitting
    a punching bag or swinging a tennis racket or bat. The results for the
    suspension parts could be breaking of dust boots on items like ball
    joints and flexing of solid rubber items like the lower control arm
    inner bushing. The flex or bind of the solid rubber bushings creates a
    "memory" that can alter the ride height (the distance from the ground to
    a set point on the frame) or cause steering irregularities like
    "pulling" or "drifting". I have found that resting the car on four 2 ton
    (plus) jack stands padded with cotton hand towels placed under the rear
    leaf spring plate and under the front lower control arm as close as you
    can get to the ball joint with out hitting the tire is the best you can
    hope for and still keep the tires on. One more advantage of resting the
    car on the suspension is that the clearance of sway bar to balancer on
    certain vehicles is decreased or eliminated all together when the
    suspension is allowed to hang resulting in the balancer and sway bar
    grinding into each other when you turn the motor over by hand or by
    starting and running it. One other recommendation is to always run the
    engine till it reaches operating temperature in the cooling systems and
    exhaust to rid the motor and exhaust of condensation. I hope this helps.
    David P. Randal
    Randal's Restorations Inc.
    www.comfortcarconnection.com <http://www.comfortcarconnection.com/>
    830-995-5237 shop
    830-822-4247 cell
    -----Original Message-----
    From: shelbymustang-bounces (AT) thecarsource (DOT) com
    [mailto:shelbymustang-bounces (AT) thecarsource (DOT) com] On Behalf Of
    RSANTER (AT) aol (DOT) com
    Sent: Thursday, August 10, 2006 10:02 PM
    To: dennis (AT) urimn (DOT) com; shelbymustang (AT) thecarsource (DOT) com
    Subject: Re: [Shelbymustang] Jacking up and jack stands? for Jody
    things about having the car off the suspension but have yet to figure
    out why it is so bad (other than for the shocks). one option is to just
    have it on a second set of cheap tires/rims.
    bob
