Re: Space saver question
Discussion in 'Shelby Mustang List' started by Robert Gaines, Nov 18, 2005.
  1. Lee the diameter is the deciding facter for your purposes.Bob G.On
    Thursday, November 17, 2005, at 09:36 PM, GT350HZ@aol.com wrote:
    > First for those who may not understand, I am trying to figure out what
    > is the best solution for a spare tire for a 1969 GT350 that is used as
    > a daily driver.  Currently my solution is a can of fix-a-flat and a
    > cell phone.
    > I guess I am slightly confused about the whole tire situation of what
    > will fit in the trunk.  If a standard tire and 15" Shelby wheel would
    > be a problem, then do I need a thinner rim and tire, or just something
    > smaller in diameter?   The offset will need to be similar to the Shelby
    > wheel so that there is not problem in clearing calipers.  I thought the
    > diameter of the tire wheel + aspect ratio of the tire should be the
    > same as the tires on the car to prevent any problems with the rear end
    > (in case it is used in place of a rear tire). The width of the tire was
    > narrower on an E 70 (185-195mm) than an F 70 (205mm) series.  So if an
    > E series would fit, then the width of the tire is the difference from
    > what I know about tires. I measured a 60 series tire on a 15" rim is
    > about 25" in height.
    > My 17" wheels with 40 series tires (on my cobra) is about the same
    > height as the 15" with 60 series tires.  I really don't want to have to
    > mount tires on a wheel to see if they will fit.  Suggestions?
    > Am I just making this difficult or is the situation just messed up?
    > Lee
    > 66 # 869
    > 69 # 2055
