Shelby Tach wiring?
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by Texas GT350, Feb 21, 2010.
  1. Texas GT350
    Texas GT350 Well-Known Member
    Houston, Texas
    Another question this time on the tach. The previous owner added the MSD 6AL system, this system removed one of the dual points and added an amplifier to the distributor. After the installation the Shelby tach no longer functioned but the previous owner seemed to accept that. I contacted MSD and they said I need the 8920 Tach Adapter which I bought. The instruction are pretty simple, plug the white wire into the tach output on the MSD box, black wire to ground and the red wire to the original trigger wire (original coil + wire).
    I located the wires out of the Shelby tach, one is blue, one is red and one is black. I figured the black would be ground. The question concerns the red one and the blue one. One should be the 12V supply (for the light and power) the other should be the original wire to the coil (I suppose).
    Does anyone know which is which?
    Has anyone else added the MSD 6AL system to their car? It seems to work very well as the car will fire off in just a few revolutions even after setting for a week.
  2. zrayr
    zrayr Well-Known Member
    TX
    the blue wire is for the light (the light is grounded via the attaching screw from the mounting bracket to the dash).
    The tach is wired in series, so the black wire is not for grounding. I have a MSD set up and you wire in the 8920 tach adaptor exactly as the instructions for it say to do. Do you have the instructions? You use the "current triggered tach example".
    The ign. switch wire that is hot when the key is turned on goes to both the red on the msd box and to the red tach wire. THe other (black) tach wire goes to the red on the 8920 tach adaptor.
    Z. Ray
  3. Texas GT350
    Houston, Texas
    Z. Ray,
    Thanks for the information, I do have the instructions but could not figure out which wire to tap the red wire (from the tach adapter) to. I never would have thought or known that the black wire is not a ground, I appreciate the tip. I will hook up the red wire to the black wire tonight and let you know how it works.
    Ron
  4. zrayr
    TX
    you can find a '66 wring diagram online somewhere, I'll try to find a link for it. It helps to have a Mustang wiring diagram to help figure these things out.
    here it is:
    http://midlife66.com/wiring/wiring.html
    a goggle search for "1966 Mustang wiring diagram" will get some more hits.
    Z.
  5. Texas GT350
    Houston, Texas
    Thanks for the link, I did find an "original type 1966 Shelby Tachometer wiring diagram" on Tony Branda, it shows 4 wires out of the tach, a green one that goes to the (-) side of coil, a red one that goes to the ignition switch and then on to the (+) side of the coil, a "short" red that is for the light and the black that goes to ground. I will have to look closer at the wires I found last night and with the help of the wiring diagrams from your link hopefully figure this out.
    Ron
  6. zrayr
    TX
    the Branda info is for a reproduction "Shelby type" tach. The info I gave you is for an original Ford (rally pack) or original Shelby (made by Faria) tach. If you have a reproduction tach I can't help as I have no experience making one work with a msd ignition.
    Going over your first post, it seems you have an original tach (3 wire from it), so the instructions I gave above should work.
    Z.
  7. Texas GT350
    Houston, Texas
    Z. Ray,
    It is hooked up and works perfectly. When I got home tonight I traced the end of the black wire and it plugged into a red wire. Using the splicer from MSD I tapped into it, plugged the red wire in, then hooked up the white wire to the MSD box and the black to ground. Pretty easy.
    Now I just need to find a place to mount the tach adapter, I currently have inside the car and ran the white and black wire through the firewall. If I cannot find a suitable place in the car I will put in the engine bay near the MSD box.
    Thanks for all the help.
    Ron
  8. zrayr
    TX
    I put mine on the inside (backside) of the bottom lip of the dash, kind of mid way between the glove box and the ash tray. There was already a hole there so I didn't have to do any drilling.
    Z.
