[Shelbymustang] 65 K Convertible Project from Orlando Mustang
Discussion in 'Shelby Mustang List' started by ORLMUST@aol.com, Aug 4, 2006.
  1. TheCarSource.com Shelby Mustang List
    8/2/2006
    Orlando Mustang
    Pete Geisler
    407 688 1966
    Please see our present ad on Ebay for details and Photos.
    Use hypert-text to quickly pull up ad: _Ford : Mustang_
    (http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=8221285&site=0&ver=LCA080805&item=22001351
    9352&lk=ItemDescriptionANDimage)
    1965 Mustang Convertible Hi-Po
    A True K-Code, Unrestored, Very Very Original and Even More Rare Than A
    Shelbyl!! It is unknown how many exactly were produced, but I have only seen a
    few.
    Vin# 5F08K252098 Built August 3, 1964 ( 64.5 ?? )
    Factory Original Options: High Performance V8 289 w/ 271Hp, Borg Warner
    4spd Toploader, (5) Original Style Steel Wheels, Console, Two Spd. Wipers,
    Am-Radio
    This is one the most Rare and unique cars we at Orlando Mustang have ever
    owned. This car is from our private collection. We purchased this amazingly
    preserved Convertible from the original owner in 1999. As did the previous and
    original owner, we have tried to preserve and maintain this rare find.
    This Mustang has only been driven 60,709 miles, and has been garaged/stored
    the last two decades. Over the years, the original owner made very few
    modifications the vehicle. Some aftermarket gages were installed under the dash,
    a Shelby style tach was added to the dash( no holes drilled), and a 2X4
    intake was partially installed, but never completed. In addition the floors
    had some minor floor work/ repairs with the carpet and seats removed. This left
    the car in a un-drivable condition. When we purchased the car in the fall
    of '99, she had four flats, a thick layer of dirt/dust over entire car and it
    had not been moved or started for quite sometime...
    After purchasing the car we gathered up all the loose parts/pieces and began
    to decode what we discovered was so rare. First to Engine Bay, Every Man's
    First Stop. Engine runs. Started again just recently. No smoke, Needs
    Tuning, has not run in years
    1. Engine Tag 289 65 5 4H 554I
    2. Original 289 K-Block w/ Vin# 5F08K252098 Clearly Stamped Date Code
    4G29
    3. Original Hi-Po Heads #21's Date Code 4G9
    4. Original 4V Intake Date Code 4G29
    5. Original Duel Point Distributor Date Code 4G4
    6. Original Hi-Po Balancer Part # C30F
    7. Orginal Radiator Part # DEP C3DE BE 1
    8. Original Lower/ Upper Crank Water/Pump Pully
    9. Original Hi-Po Fan Blade Part # SC30A-C
    10. Original Carter Fuel Pump Part # 1719 W/original Autolite can
    11. Original Alternator w/ very lite Autolite Ink Stamp and Hi-Po Larger
    Diameter Pully
    12. Original Timing Cover, Early Style Part # C4AE-6059 B
    13. Original Water Pump Part # C5AE-8505 C
    14. Original Distributor Cap, Points (Not Wires)
    15. Original Valve Covers Not Repo's
    16. Original Voltage Reg. Water Bag, Pump, All Wiring,
    17. Missing Original Carburator, installed Holley 4160
    18. Missing Original Exhaust Manifolds, Installed Ceramic Coated New
    Tri-y's
    Starting to get the Picture??
    Transmission: Original, Vin # 5F08K252098 Clearly Stamped on Flange, tag w/
    original linkage and shifter box/handle
    Rear Axle: Original 9" , untouched w/ original tag
    Suspension: All original w/ exception of the shocks
    Exterior Paint: Amazing Original Paint From the Doors Back. There are some
    scratches and dings from being driven and stored over the years. Most of the
    dents visible in pictures. Original Paint in Trunk, Door Jams, Trunk Jam, The
    Front Fenders and hood were repainted many years ago, due to very light
    front accident. The current hood is a '65, but I have a new OEM Ford Tooled, Not
    A Cheap REPO actual 641/2 Hood w/ Proper Winged front Edges New In Box.( cost
    $450) Take your choice of the Hoods. New Front Valence Painted To match car
    installed, Overall its very presentable, but needs to restored someday...
    Exterior Chrome: Orginal Rear Bumper, Gas Cap, Dealer Emblem(Very Rar),
    Bumper Guards, Convertible Boot Chrome w/ Snaps, Quarter emblems, Windshield
    Chrome (excellent), New Repo Front Bumper, Original Horse & Corral, Grill
    Glass: Original Side Glass, all in Excellent conditon, NO Scratches, Front
    Windshield was perfect, Cracked Horizontally, Quarter glass Perfect, Vent
    Wings, Some Pitting,useable
    Convertible Top: All Original, ( I have never seen one), very worn, Torn in
    several places, great sample, Top frame is in good condition, and power top
    is fully operational, no problems
    Wheels: 5- Original 14x5 Style Steel Wheels w/ (4) new 195/75 Tires,
    Includes (3) Original Black Steel Wheels Dated 4m. Spare tire is probably original
    dated 4M w/ US Royal dual Red Line tire 6:95X14, Original Jack Handle and
    Early Tie Down Hardware
    Interior: All original Seats, Door Panels, Dash Pad, Console, and Paint,
    Seats are excellent, some small stains, driverside has on weak spot 3"(
    splitting seam, easy fix), Original heater box, and very rare cardboard plenum
    (perfect condition) A-fresh air vent, original steering wheel ( small cracks, can
    repair) Overall again very well preserved, may have to repaint metal areas.
    Body & Rust History: Unfortunately this vehicle started as a daily driver in
    Ohio, so the rear quarters and floors have some rust. The rust is mostly
    contained the rear quarters, and the floors.There is very little surface rust
    above the rockers anywhere on the car. It will need the L-lower quarter and
    wheel house area repaired, However the R-quarter will probably have to be
    changed due to the rust in the wheel lip. Most of the rust is just in this area.
    Front Floors need what I call half pans, from the edge of the sub-rail to the
    rocker, The rear floors had some small patch work years before, and could be
    left alone or cleaned up. Both L/R Inner rockers have some small holes, not
    sure if partial rails could be installed, its not problem right now, maybe in
    the future. No rust in the door jams or trunk jam, Some rust at trunk floors,
    see picture. Excellent doors, minor surface rust on bottom edges, L/ R
    Fenders no signs of rust at all. Cowl test failed, so it needs cowl hats. Front
    fender aprons, are excellent, small rust area at firewall and cowl area
    r-side??, Front core support was changed many years ago when hood was changed
    mostlikely at Ford dealer. (hard to detect), Correct 641/2 Headlight buckets.
    Original grill and hardware.
    If the front fenders and hood had not been repainted years ago, this would
    be what MCA calls a Survivor Car. One that has 80% original paint and mostly
    original parts. Well this car falls into that catagory if you discount the
    paint issue. This Mustang still wears what I would call 60% Original Paint,
    Original Interior, Original Trunk and Accessories, and Most Definately that all
    Coveted 271hp V8 package.
    Future: This car could be brought to daily driver standards very easily, and
    affordable. More importantly though. It could restored to the highest
    standards of MCA, Concours Trailered with all the original parts and pieces
    incorporated into the restoration making it one the most valuable and rare cars to
    this day.
    This car is available to viewed by appointment in Osteen, Florida
    It runs on a bottle of gas due to the original tank has debris
    Brakes are complete but need to be rebuilt. All lights are operational. Car
    will drive around the block but is un-safe to drive until brakes and fuel
    tank are addressed
    If you have more questions or would like more information Please Contact
    Pete c/o Orlando Mustang 407-688-1966
    We reserve the right to end Ebay Auciton Early to a Qualified Buyer!!!
    Call Pete to arrange inspection
    _______________________________________________
    ShelbyMustang mailing list
    Send email to ShelbyMustang (AT) thecarsource (DOT) com
    Membership Administration http://thecarsource.com/mailman/listinfo/shelbymustang_thecarsource.com
    Group Web Page http://www.thecarsource.com/shelbymustang
